To the right of the rightmost top intake manifold stud is a sensor, to the right of it is a bolt that I found to be loose. Any ideas?
I've just ran a few miles with the bolt removed, and it's spraying oil all over my nice clean inlet manifold, rocker cover, etc...
It bolts into aluminium - the threads are (now) stripped. The bolt's been loose before, and when snugging it up, it kept turning and brought three threads worth of swarf out with it.
Whatever it is that it's bolting into is at the front of the block, under the front most end of the head, and from the driver's side looks like it goes a little way back, ie along the front of the block. It's just under the coolant outflow stub.
Going to look at some 'sploded diagrams, but need to know:
- what is it threading into?
- why is it spraying oil?
- what's the best remedy?
