EGR Blanking, pro's n cons ?
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Re: EGR Blanking, pro's n cons ?
Post by M 80NGO » Fri Nov 11, 2011 11:32 pm
Driver+Passengers wrote:
M 80NGO wrote:Ok some great info on this post and i've read it all with great interest, just 2 things that puzzle me :
1) surely the pipe that's being blanked will fill with crud again bearing in mind that the crud seen in the pics could be 16 years worth of crud ?
If the pipe is blanked, there will be no further crud deposited within it, as there will be no more dirty air going through it.
M 80NGO wrote:2) why is it not just as easy to take it all off clean it all out and then refit complete with EGR as mazda intended ?
If you choose not to blank it, then you may still want to take the manifold and EGR pipe off to inspect, clean and refit - on the assumption that it's not going to be spotless in there, particularly if you're getting the characteristic weeping gunge around the gaskets. Blanking is easier because you don't have to remove and clean, but I'd argue that you'd probably want to remove and clean the inlet manifold and elbow. At which point, it's 6 and two 3s whether you blank or refit. Cleaning out and replacing gaskets is going to be a good job in itself, it's just you may have to do it again a few years down the line.
I get the impression that "as Mazda intended" may be subject to differing opinions. Japan's strict(er) emissions regs require the EGR to reduce nox, and I've read at least one post where the author reckons it 'looks like an afterthought'.
We may be biased towards blanking due to the collective reports that (crud-wise) it "does more harm than good", performance seems better after blanking, it's easy to blank, etc... It is clear, though, that this should not be the final answer.
It doesn't seem like a big deal to include cleaning out and resealing it all into a service regime.
That's what I reckon, anyway. I blanked it because it felt like the right thing to do - who knows?!
Makes perfect sence to me =D> i think i'll remove clean and refit as mazda intended to see what if any improvements are made tho i have to say that i have no weeping oil problems and the last time she was mot'd the tester done the emmisions twice cos the reading was so low he thought his reader was on the blink :D
scanner
Post by scanner » Sat Nov 12, 2011 12:07 am
It's not "as Mazda intend" it's as "the people who set the emissions standards intend".
No self respecting engineer worth his/her salt would even think about fitting EGR to an engine as the very concept (feeding mucky, filth laden, used exhaust gases back into the inlet manifold) goes against all engineering principals.
As I said earlier the first thing the mechanics at Perkins did when they got a diesel in for a service was disconnect the EGR.
There is a world of difference between what engine makers have to fit and what they would choose to fit.
<EDIT> Superfluous "n" deleted.
Driver+Passengers
Post by Driver+Passengers » Sat Nov 12, 2011 12:11 am
scanner wrote:It's not "as Mazda intend" it's as "the people who set the emissions standards intend".
No self respecting engineer worth his/her salt would evenn think about fitting EGR to an engine as the very concept (feeding mucky, filth laden, used exhaust gases back into the inlet manifold) goes against all engineering principals.
Insightful. =D>
(Edit: Thinking about it, I think this is precisely why I blanked mine.)
Image Image
briwy
Post by briwy » Sat Nov 12, 2011 12:20 pm
Exactly.
Iv'e been trying to find out a bit more about the EGR as I have this fitted on our van and wanted to know if I can get rid of it as it's just in the way.
Its obviously a heat exchanger for the EGR and I assumed, wrongly, that it was for heating the exhaust gases. Stupid I know as they are already hot. It is in fact for cooling them before passing to the EGR system. (see this informative fact sheet which incidentally describes what all the turbo gubbins are that I wanted to know about in my Eberspacher thread)
http://www.igmaynard.co.uk/bongo/member ... ontrol.pdf
This would indicate to me that Mazda realised that it is not a good idea to be passing hot exhaust gas into the inlet manifold, after all the intercooler is there to cool the input charge, and then just before it enters the head the EGR is trying to warm it up again. As pointed out already its just to try to keep the emissions down for various regulations. Our previous Bongos had the EGRs blanked off and sailed through the test with flying colours so to me the whole EGR thing is a waste of space.
Ady has a point when he says it will help a faster warm up thus aiding fuel consumption. I agree this must be true but once up to temperature the EGR would appear to do the opposite by heating up the charge which will reduce fuel consumption.
So for me it definitely is blanked.
Hope all this makes sense.
Post by Northern Bongolow » Sat Nov 12, 2011 10:34 pm
brian is the unit in the above picture just something to help stabilize/control the heat in the exhaust manifold.
i have no access to the link above, and have not seen the unit in the flesh, or how its piped in, is it not something to help stop the exhaust manifold from warping,and doing the no1 stud etc.
briwy
Post by briwy » Sat Nov 12, 2011 10:54 pm
Ady, no the EGR pipe comes out of the turbo into this unit before going into the EGR valve.
pm sent
Post by Northern Bongolow » Sat Nov 12, 2011 11:12 pm
so the unit is cooling the exhaust gasses coming through when warm, but warming when engine is cool, if it operates at low temps.
cheers brian.
