lpgimports wrote:If anyone ever wants me paul at lpgimports.co.uk or a PM which triggers a email anyhow. Sometimes am really busy and when I get home computering is last thing to do, other times I am online till early hours.
Paul
Hi Paul. Thanks for all the info above. Yes, temporary fix only at present, as far as I'm concerned, although still going strong up until now. That sounds a good place for the LPG ECU, and you obviously agree that accessibility is a prime consideration. When time and weather permit, I'm going to pull the old Bongo to bits somewhat, to get at that loom, and may be able to reposition the LPG ECU as you suggest, while I'm at it. As I already said (and as I'm now more than a bit suspicious about the original installation quality, anyway), I'm definitely going to take a close look at all that loom soldering work - and yes, intend to attack the ECU to loom connections with switch cleaner. As an RAF-trained former aircraft radio fitter, I fancy I know a bit about soldering, and keeping connections good - if we didn't solder well, or ensure connection integrity, the consequences could quickly be pretty dire
To use the two spare injector driver ouputs in an LPG ECU, do you have to re-programme it, or can you identify loom inputs and outputs easily, and just transpose the connections? That could be very useful, if an LPG ECU driver circuit goes down - have you known that to happen?
Am writing to ask Ian to update the LPG Fact Sheet, from talking about ECUs working in parallel to ones working in series, which might help to reduce the number of petrol running faults that peeps report with LPG conversions. It probably needs expressing in simpler terms than either of us has done so, so far though - working on it!
Didn't PM you, as I thought it should be something I could sort out with a bit more application but I would have called in to see you, passing by some time, if I hadn't managed to. PM and subscribed-topic email alerts are not working at the moment, due apparently to a server problem, and that was another reason I didn't. Reminds me that I need to add "PM sent" in a couple of threads, for that same reason - just realised why messages haven't been read
Cheers,
David
