Hi all,
I have a diesel Bongo 96 reg.
I noticed that the fuel filter has been disconected and an inline filter put in its place.
Am I simplifying things to think that a filter is just a filter.....after all the inline filter has a mesh in it so it will stop any particles and therefore do the job??
Anyone else have this set up or any opinions from the experts?
Cheers Gang
Fuel Filter
cardiff996
Re: Fuel Filter
Hi cardiff996,
The standard manufacturers fuel filter is a wee bit more than just a filter,it has a sediment/water trap and a warning system incorporated.
Cheers.
Cheers.
Re: Fuel Filter
The proper filter unit has a moisture trap & sensor to indicate you have a build of of water in the bottom, as well as the ability to drain off the moisture. Presumably Mazda fitted this instead of a cheap in-line filter for a reason, so my recommendation would be to investigate why it has been bypassed & consider reconnecting it back up. If you find there is a fault with the filter assembly, I have a spare one available in exchange for some beer tokens
Re: Fuel Filter
These relevant links to diagrams from tank to pump may help too...
cardiff996
Re: Fuel Filter
Hi all,
Thanks for the info and sorry for the delay in replying.
I think I will take the advice and look to connect the filter back on to the fuel lines. Wont drive to far though in case it conks out!!
- The Great Pretender
Re: Fuel Filter
How long have you had the Bongo?
If the previous owner was such a tight ass that he wouldn't replace the filter or bypassed a warning light alarm bells should be ringing.
If I were you I would take it to a Bongo specialist and have a full service and health check.
To infinity and beyond
