Exhausts
PisceanJoy
Exhausts
Post by PisceanJoy » Mon Dec 26, 2011 6:15 pm
The back of my exhaust has just fallen off
Haas anyone bought one recently and know how much they are
Have seen how much it is in bongo shop
Re: Exhausts
Post by francophile1947 » Mon Dec 26, 2011 6:20 pm
Fit a straight pipe instead - cheaper, better and fitted by loads of members 8)
PisceanJoy
Re: Exhausts
Post by PisceanJoy » Mon Dec 26, 2011 6:34 pm
without the back bit?
I have a Diesel bongo
Has anyone near me done this?
teenmal
Re: Exhausts
Post by teenmal » Mon Dec 26, 2011 6:56 pm
PisceanJoy wrote:without the back bit?
Hi,I believe that a Ford Connect tailpipe will fit with a bit of fiddling.
Just remember that removing any major part of an exhaust system is a MOT failure,but I think you would need a switched ON Tester to spot it on these vehicles.
Cheers.
Re: Exhausts
Post by francophile1947 » Mon Dec 26, 2011 7:38 pm
teenmal wrote:Just remember that removing any major part of an exhaust system is a MOT failure,
Not unless the rules have changed recently. Providing there are no leaks and it isn't too noisy, it will pass an MOT.
Re: Exhausts
Post by Muzorewa » Mon Dec 26, 2011 7:43 pm
...and it can't be any noisier than ours from MIJ in Walsall :?
PS - who I would wholeheartedly recommend :wink:
scanner
Re: Exhausts
Post by scanner » Mon Dec 26, 2011 8:11 pm
As I've said before the standard "oil drum" is a waste of space and weight.
If you have a decent local garage or exhaust fitter ask them to source and fit a small straight through box - it's all you need.
Aethelric
Re: Exhausts
Post by Aethelric » Mon Dec 26, 2011 11:41 pm
£47.50 from A TO Z AUTOPARTS (MIDLANDS)LTD. I just fitted mine today.
PisceanJoy
Re: Exhausts
Post by PisceanJoy » Tue Dec 27, 2011 11:26 am
PisceanJoy
Re: Exhausts
Post by PisceanJoy » Tue Dec 27, 2011 11:30 am
Aethelric wrote:£47.50 from A TO Z AUTOPARTS (MIDLANDS)LTD. I just fitted mine today.
Have you got a URL / contact no for them google serach doesnt find it
:x
Simon Jones
Re: Exhausts
Post by Simon Jones » Tue Dec 27, 2011 11:44 am
Lots of results on google including this with contact details;
http://www.yell.com/b/A+to+Z+Autoparts- ... index.html
rita
Re: Exhausts
Post by rita » Tue Dec 27, 2011 11:49 am
Hi,you could try these people,they have sold quite a lot.
http://www.ebay.co.uk/itm/MAZDA-BONGO-1 ... 1c1a40a62c
mikeWalsall
Re: Exhausts
Post by mikeWalsall » Tue Dec 27, 2011 11:54 am
Simon Jones
Re: Exhausts
Post by Simon Jones » Tue Dec 27, 2011 12:06 pm
Worth noting there are two types of exhaust systems. The most recent link from Mike is the 4 part version for vans with the winter warm up valve fitted, but there are probably more Bongos out there with the 3 part version. While the backboxes will probably be the same in both cases, the front section is not interchangeable. If the front section is in good nick, then I personally would just replace the broken bit.
