I asssume the electric window switches in the doors light up?
If so how do I remove them to change the bulb?
Window switch bulbs
Re: Window switch bulbs
No lights unless you put leds in yourself!!winchman wrote:I asssume the electric window switches in the doors light up?
_____________________________________________________________Dabs wrote:No lights unless you put leds in yourself!!winchman wrote:I asssume the electric window switches in the doors light up?
yep! doing that right now
How?
Could we have a picture please?
Done mine a good while back too... Set up the wiring when i installed the remote CL & window roll up module...mentaliss wrote:_____________________________________________________________Dabs wrote:No lights unless you put leds in yourself!!winchman wrote:I asssume the electric window switches in the doors light up?
I got a switch out of a 626 as a replacement.. The original was butchered by the previous Jap owner..
The cameras a bit sensitive, but in the dark...
I also got it to go red when i hit the panic button, the van locks down & the windows roll up... The 626 rocker switch is wired different to the Bongo's
very posh
jaylee's job sounds better than my ideal as he's used back lit switches im using miniture LED (blue) fitted (drilled) into the indentations of the switch cover, new micro wiring from the LED's through the doorway into the cab eventually linking up to the sidelights, Im not sure if Jaylee's ideal is easier work wise than mine he sounds like he has a sound understanding of electronic's so if I had'nt started mine my way I would have adopted his ........ but at the moment its far too cold to carry on with the work!winchman wrote:How?
I just bunged a couple of spare LEDs in the gap so as not to foul the switches....mentaliss wrote:jaylee's job sounds better than my ideal as he's used back lit switches im using miniture LED (blue) fitted (drilled) into the indentations of the switch cover, new micro wiring from the LED's through the doorway into the cab eventually linking up to the sidelights, Im not sure if Jaylee's ideal is easier work wise than mine he sounds like he has a sound understanding of electronic's so if I had'nt started mine my way I would have adopted his ........ but at the moment its far too cold to carry on with the work!winchman wrote:How?
I'm looking forward to seeing you end result Mentaliss...
Mine was wired from the live into the dash back-light loom & earthed in the door..
It was a bit of a fiddle, but i was reparing the door loom anyway..!
