Crank shaft oil seal front
delbouy
Can anyone tell me if it is a big job to change the front crank shaft oil seal
Re: Crank shaft oil seal front
No its not a big job,about 20/30 minutes (all going well)
Make sure the IP seal is not leaking.
Cheers.
Cheers.
delbouy
Thanks for the reply but can tell me what an ip seal is
Sorry if I'm being a bit thick
Hi delbouy,
There is also another oil seal,(Injector Pump pulley seal)On the timing gear cover,but I would think it more likely that it would be the crankshaft seal.It was just an after thought.
Good luck.
Good luck.
