Derek
Moderator: Doone
Thanks. She is running fine again, but I think it's worth a filter change anyway. I have no idea when it was last done, so it won't hurt. I was thinking of adding an in-line filterchipvan wrote:Prob not the filter if now ok,just always best to mix out of the tank before you throw in.not as bad when warmer...it will be fine just maybe use a Lower mix..don't throw it away it looks like you just added too much that's all
Was the engine coldDr Fingers wrote:After 'jumping' Ruby up and down the drive, blockage seems to have cleared. However, once she was feeling better, trotted off and whacked some diesel in on top of the sunflower.
Dr Fingers wrote:Thanks. She is running fine again, but I think it's worth a filter change anyway. I have no idea when it was last done, so it won't hurt. I was thinking of adding an in-line filterchipvan wrote:Prob not the filter if now ok,just always best to mix out of the tank before you throw in.not as bad when warmer...it will be fine just maybe use a Lower mix..don't throw it away it looks like you just added too much that's all
http://www.ebay.co.uk/itm/150479838563? ... 1952.l2649
Any reason why I shouldn't? Seems to me it would be much easier to replace one of these than the main one.
Derek
