rear heater
Bongolitus
rear heater
My 1998 4WD 2.5 TD Bongo is needing a new bit.. it's the pipe that feeds the rear heater..not sure of its technical name but it comes out the engine, heads towards the back..there's a T junction in it as well.. Sorry to be so vague but if anybody can help with proper name of part or even part number that would be grande..
Re: rear heater
See anything you recognise on here....? http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Bongolitus
Re: rear heater
Thanks Jaylee.. I'll show this to my mechanic..I'm sure it will be of great help.. thanks again
Re: rear heater
You description sounds like it could be part 61-2D1...? It's a metal pipe with a tee piece in it, under the drivers seat, but closer to the sill...?
Bongolitus
Re: rear heater
Thats the one..many thanks... this just shows the benefits of joining the club..cheers
Re: rear heater
Did your mechanic mention whether the metal pipe had a leak due to corrosion, or is it the rubber hose connecting it up??
Re: rear heater
They are quite tricky to get hold of new. I know where there is a second hand one, but it may not be in much better condition than yours.
Bongolitus
Re: rear heater
He reckoned it was the pipe..
Re: rear heater
Hi. I`ve just recently fitted a new one of these pipes,genuine Mazda part,no.S09A-61-22YA.Simon Jones wrote:They are quite tricky to get hold of new. I know where there is a second hand one, but it may not be in much better condition than yours.
This is the metal pipe that goes from the front heater,has a tee to the engine block and then to a rubber hose to feed the rear heater.
My Bongo`s a V6 but i believe the pipes the same on all models.......
I got mine from Bongobits,but be warned,you don`t get much change out of £90 and i had to wait just over 3 weeks for it even though i was told a couple of days.
You could feed 16mm rubber hose in place of the metal pipe,connecting using tee pieces and straight connectors,good bit cheaper n`all
Year 2000 V6
Bongolitus
Re: rear heater
Thanks Simon..I'll have a word with mechanic to make sure..but I'm pretty certain we're on the right track now.. Thanks again
Re: rear heater
I had the same and replaced mine with 16mm rubber heater hose from the front with a T piece at the back .
Never had any problems
Now taken leaking rear heater out ard replaced the one that goes across to N/S as that started leaking when i removed heater pipe. Its not to bad a job n saves you loads.
I would walk 500 miles.
99 Tinted tintop
Supplied and looked after by Bongospares
99 Tinted tintop
