Annoying Door Beeps
tboy
Annoying Door Beeps
Post by tboy » Sat Jun 16, 2012 5:15 pm
is there any way u can disable rather than disconnect the Beeper that sounds when keys are put in ignition
and the front doors are open?
Driver+Passengers
Re: Annoying Door Beeps
Post by Driver+Passengers » Sat Jun 16, 2012 5:17 pm
Just under the steering wheel (visible through the hole in the cowl) is a two pin white plastic connector. Disconnect that connector.
This will leave you with "lights on" and "reverse" beeps. Provided you still want them, that's all you need to do.
Edit: I assume you meant this rather than disconnecting the whole buzzer box - which in so doing would lose you the lights and reverse beeps.
Image Image
tboy
Post by tboy » Sat Jun 16, 2012 5:21 pm
Thats brill. Thanks
Driver+Passengers
Post by Driver+Passengers » Sat Jun 16, 2012 5:23 pm
I just did mine yesterday - prep for the Bash.
Image Image
Post by g8dhe » Sat Jun 16, 2012 6:19 pm
Here is a picture;
If you don't pull it completely apart its easier if you do need to reconnect it later!
jaylee
Post by jaylee » Sat Jun 16, 2012 9:54 pm
I tried this one years ago & found my glow plug light kept flashing till it was reconected...?!! :-?
I opted for an isolation switch from the white wire of the beep box for "camping mode".. Disables all, bar the reverse beep.
( I think it was the white wire?)
Tucked away nicely in the fuse box..
Post by g8dhe » Sat Jun 16, 2012 10:03 pm
That's very odd, are you sure you got the right plug ? There are no connections from the SWS to the ECU and the glow-plug light - at least that are shown!
jaylee
Post by jaylee » Sat Jun 16, 2012 10:15 pm
The very same plug Geoff.! I cant see any connection with the ECU either...
This beep stop tip is one of the first i tried when i joined the forum.. To my knowledge no one else has had this happen..
All i remember at the time was when the engine was running.. (or may have been pe-warm up?) It flashed... I thought oi oi that ain't right & plugged it back in..
tboy
Post by tboy » Tue Jun 19, 2012 5:45 pm
simple when you know how.Connection under steering cowl disconected.NO BEEPING DOORS!! But still have lights on and reverse beeps PERFIKT.Thanks for the info.
Simon Jones
Post by Simon Jones » Wed Jun 20, 2012 12:49 am
Just did mine too. Thanks for the inspiration to get this little job sorted :D
sdsk
Post by sdsk » Wed Jun 20, 2012 8:23 am
I tried unplugging mine last night, the little wotsit wouldn't shift.....
Any handy hints or am I just being a bit too careful?
Darron
2001 Aero 2.0l JAL Skylift roof & K2 Campers Intrepid Rear conversion in Carbon Fibre
Driver+Passengers
Post by Driver+Passengers » Wed Jun 20, 2012 8:50 am
sdsk wrote:I tried unplugging mine last night, the little wotsit wouldn't shift.....
Darron
Really have to push down the springy-tab-lock bit. I think you might be being careful. Don't break it, though... ;)
Image Image
jaylee
Post by jaylee » Wed Jun 20, 2012 8:50 am
Hi Darron,
I seem to remember a clip topside of the white connector that hold the two half's together... :idea:
tboy
Post by tboy » Wed Jun 20, 2012 10:18 am
On mine it had a clip on the right side as you look at it from the drivers door ,that needs to be depressed whilst pulling apart.similar to all plastic electrical connectors that are used in the Bongo.
Rebiam
Post by Rebiam » Wed Jun 20, 2012 11:57 am
Superb tip - thanks guys. Now if only the kids had the same arrangement for their annoying noises...................... :D
'98 Green over Silver 4WD AFT
Everyone has a photographic memory. Some don't have film.
