EGR Valve?
happeninboy
EGR Valve?
Post by happeninboy » Tue Aug 14, 2012 10:56 pm
My Orange light started to flash today and the Bongo found going uphill rather a struggle thereafter.
The AA man said that he didn't have the right plug for the diagnostic but was pretty sure that it was an EGR valve problem.
Do you agree and if so is this expensive to rectify?
Kind regards
Re: EGR Valve?
Post by Bob » Tue Aug 14, 2012 11:33 pm
Hard to say without knowing if there is a symbol on the orange light, but I'm not aware of a EGR warning light.
Re: EGR Valve?
Post by Northern Bongolow » Tue Aug 14, 2012 11:37 pm
which bongo have you got, and what year.
happeninboy
Re: EGR Valve?
Post by happeninboy » Wed Aug 15, 2012 7:38 am
It's the glo-plug coil light that's flashing. It's a 2.5 diesel in a Yr 2000 Bongo. Many thanks.
Re: EGR Valve?
Post by Bob » Wed Aug 15, 2012 10:00 pm
Anyone got any thoughts on this one? :)
Re: EGR Valve?
Post by francophile1947 » Thu Aug 16, 2012 11:52 am
Just did a search and this lot came up http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search
Together with the fact sheet in Member's Area, it should give you loads of info 8)
happeninboy
Re: EGR Valve?
Post by happeninboy » Thu Aug 16, 2012 8:57 pm
Thanks guys,
My local garage knows someone with the correct diagnostic plug so I'll take it down there.
I took it for a run today. It stared off not flashing but then after a while it came on. When I got home the console and handbrake felt warm so maybe it's the scavenging fan, as the handbook (which I have subsequently read) suggests it may be!
Also, believe it or not, my local Mazda dealer said that he can help too...although he's going to charge me £45 just to run the diagnostic...my wallet aches already!
N.b The AA man couldn't make head nor tale of the diagnostics factsheet!
Anyway, hopefully I'll get this sorted soon...many thanks again for your help.
cavey
Re: EGR Valve?
Post by cavey » Sat Aug 18, 2012 5:12 pm
Same symptoms as mine and same age. I've not got to the bottom of it yet, but I believe it could also be one of the many vacuum solenoids. Where abouts are you happenin'?
Cheers,
Dave
happeninboy
Re: EGR Valve?
Post by happeninboy » Mon Aug 20, 2012 8:55 pm
Surrey/W.Sussex Border.
It's in the garage now...will post again once the diagnostic has been run.
cavey
Re: EGR Valve?
Post by cavey » Fri Sep 07, 2012 1:25 pm
Any news yet? I have my fingers crossed for you (and me!), as I've read some horror stories on here... Lots of positive ones too, but it's only the bad ones that stick in my mind (until I get it sorted that is). I've been a bit busy recently though.
Cheers,
Dave
happeninboy
Re: EGR Valve?
Post by happeninboy » Mon Sep 10, 2012 12:01 am
Nope, my garage drew a blank so I'm biting the bullet and taking it to Mazda Guildford on 13th...hopefully we'll get somewhere after that!
Re: EGR Valve?
Post by Northern Bongolow » Mon Sep 10, 2012 9:14 am
on this later type turbo it has a habit of failing on the wastegate flap, get them to check it out. it can stick causing your symptoms.
happeninboy
Re: EGR Valve?
Post by happeninboy » Tue Sep 11, 2012 12:52 am
I certainly will, many thanks!
Tidmo
Re: EGR Valve?
Post by Tidmo » Tue Sep 11, 2012 8:21 am
Hi happeninboy, mines had this a couple of times and had turned out to be a faulty air control valve.
Id be tempted to take a trip to a Bongo savvy garage (321 away, Bell Hill, ADS Bristol) to get your code read, Mazda generally cant help what with it not being a EU model.
I can recommend all of the mentioned garages (all an hour plus from me!)
Keep us posted on your findings. :D
Pourquoi Pas?
TerryG
Re: EGR Valve?
Post by TerryG » Tue Sep 11, 2012 9:51 am
[quote="happeninboy"]Thanks guys,
Were you driving with the lights on? I thought I had a scavenge fan problem as the console would become very warm. Then I realised it only happened intermittently, which was odd, and then I realised that it was only when I had the lights on. Which is when I came to the conclusion that it was the bulb illuminating the gear-shift that was causing the heat build up!
'Enjoy every sandwich'
