Hi, I've fitted a tow-equipe towbar to my 1995 2.5 diesel. With grateful thanks to Moray for pointing me in the right direction in identifying which wire was the stop light feed, & which one was the tail light feed ( however, I did learn to my chagrin that I had wired up some wrongly, as I should have checked the colurs which matched up to the 2 sides of the plug connector
). However I'm now at a dead-end with the right side indicator. According to the wiring diagram, and the loom leading from the connector into the depths of my baby, the wire should be green with white stripes. However, when I strip back the loom coming down the nearside rear pillar, this particular colour is not present (Gah!! That would be too easy!) After much trying and repairing of each wire, with a tailboard from the dark ages plugged in, I finally got the right indicator on said board to only come on when I operate the indicator from inside the cab (admittedly it stayed on permanently rather than indicating as it should). However, when I plugged in my 1990 Abbey Lincoln caravan plug, I immediately got the right side indicator on permanently.
Short of either getting an auto electrician in (the likeliest outcome) or sitting in the back again & trying each wire over and over, Can anyone help please???? My annual holiday is at stake
. Does anyone know which wire it should be, or can suggest what may be wrong?
Would appreciate any helpful input.
Thank You
