EGR Valve?
happeninboy
Re: EGR Valve?
I think the console warming up may be incidental, but no, it happens with lights on or off and on long journeys or short!
happeninboy
Re: EGR Valve?
So, just got back from Mazda Guildford...Codes received: P1228 - Wastegate Failed Open (under pressure) and P0400 - EGR system flow malfunction.Northern Bongolow wrote:on this later type turbo it has a habit of failing on the wastegate flap, get them to check it out. it can stick causing your symptoms.
Time to call the warranty company methinks!
DW
Re: EGR Valve?
have a chat with julian at 321 away he is very helpful and will advise on the best way forward. he is a well respected dealer on the forum.
happeninboy
Re: EGR Valve?
Northern Bongolow wrote:have a chat with julian at 321 away he is very helpful and will advise on the best way forward. he is a well respected dealer on the forum.
Ha ha, just read this...2 secs after speaking to Julian!!
happeninboy
Re: EGR Valve?
So, went to 123, Away today where Julian ran 2 or 3 tests and concluded that it was a 3 -way solenoid valve that had failed. All sorted under warranty and within a v. short space of time...Thoroughly recommended!
Re: EGR Valve?
Sorry to revive this old thread but Gary from Helensburgh has been in touch with identical problems and identical fault codes. Do we have a part number for the 3 way solenoid valve?
Re: EGR Valve?
Ian wrote:Sorry to revive this old thread but Gary from Helensburgh has been in touch with identical problems and identical fault codes. Do we have a part number for the 3 way solenoid valve?
What age is the vehicle,you should be able to get part numbers from Lushprojects..example..showing item number18-741A 3 way valve,click on item number for part number.
http://lushprojects.com/bongopartsmk2/c ... f02.html#4
Re: EGR Valve?
I'd be very interested to know this, as I have the same symptoms and fault codes. Still not sorted yetIan wrote:Sorry to revive this old thread but Gary from Helensburgh has been in touch with identical problems and identical fault codes. Do we have a part number for the 3 way solenoid valve?
The problem is that i don't know which is the 3 way solenoid valve to find out the part number. Chicken and egg!rita wrote:
Yours hopefully
Dave
Re: EGR Valve?
cavey wrote:I'd be very interested to know this, as I have the same symptoms and fault codes. Still not sorted yetIan wrote:Sorry to revive this old thread but Gary from Helensburgh has been in touch with identical problems and identical fault codes. Do we have a part number for the 3 way solenoid valve?![]()
F2L418741 18741A VALVE,THREE WAY ???A NO.2
Yours hopefully
Dave
Re: EGR Valve?
Many thanks. You asked about year. Is this the correct part for a 2001 Bongo (Y reg)?rita wrote:cavey wrote:I'd be very interested to know this, as I have the same symptoms and fault codes. Still not sorted yetIan wrote:Sorry to revive this old thread but Gary from Helensburgh has been in touch with identical problems and identical fault codes. Do we have a part number for the 3 way solenoid valve?![]()
Yours hopefully
Dave
