I have have a 2.5 TD Auto Bongo that was fitted with the "Winter Pack" subsequently removed. I am also about to blank off the EGR valve.
My query is this: Do I still need any of the electrical units that sit above the glow plugs an associated vacuum pipes?
It would be useful to dump them if no longer required as they rather get in the way.
Vacuum Units Etc.
Re: Vacuum Units Etc.
These?
Yes you do..! They control/keep up the idle on cold start & when the AC is on..
Damn....was hoping to dump them....
Thanks for that......
Yep, they control this...
Acts like a "choke" so the van don't start/run lumpy on those cold mornings that will be coming up..!
you can do away with the rearmost 2, and repositon the front 2? just means extending the vacuum pipe
Julian
Julian
Schematic drawing may help with the pipery.... http://lushprojects.com/bongopartsmk2/c ... 1of02.html
Thanks for you advise guys. Most helpful.
