MY NEWLY ACQUIRED FORD FREDA
The sliding door does not open with my central locking with tips from the chat forum, I have checked it out up to the door frame contacts, in as much as I have operated a spare actuator at this point. So the fault is in the door have removed the door handle and panel, and mechanically is OK, so that leaves the electrical actuator see pics, are these easily obtained and are they easy to fit ?
prior owner of >>>>1999 2.5 diesel ex tin top &FORD FREDA 2000 2.0 LTR PETROL
Re: MY NEWLY ACQUIRED FORD FREDA
Hi,Colin H F wrote:The sliding door does not open with my central locking with tips from the chat forum, I have checked it out up to the door frame contacts, in as much as I have operated a spare actuator at this point. So the fault is in the door have removed the door handle and panel, and mechanically is OK, so that leaves the electrical actuator see pics, are these easily obtained and are they easy to fit ?
Is it just the picture or should the rod with the green clip not be connected to the eyelet.
Hi Rita, Thanks for your reply, Just been out and had a look and no its not supposed to be connected they are two separate items I don't know why the hale is there that particular piece of metal actually holds one end of a spring, in any case as I stated its not mechanical its electrical, because I have applied 12volts to the contacts and reversing polarity and there is nothing happening at the electrical actuator
Are you still looking for a sliding door lock..
http://uk.ebid.net/for-sale/internal-lo ... 295175.htm
Hey thanks for that but I have secured one for the same price it should be with me tomoz
