Fuel Pump Seals changed but................
rhino-wayne
Post by rhino-wayne » Mon Oct 01, 2012 6:47 pm
Hi all,
OK Changed the fuel pump seals today, was feeling happy with myself :) ...........until she didn't start! aaugh #-o :( Ran battery flat trying, battery now being charged but any ideas or suggestions folks? :?:
rhino-wayne
Re: Fuel Pump Seals changed but................
Post by rhino-wayne » Mon Oct 01, 2012 7:09 pm
and now some general comments about the seal change, I followed (dandywarhol's) fact sheet.
Tools used:
10mm ring spanner
10mm socket, ratchet & hinged unit
DIY wire tool made from a key "ring"
(Battery charger :oops: )
Tool I wish I had:
One of those mini mirrors on a telescopic pole! #-o
Note 1: I have bigger hands than dandywarhol :lol:
Note 2: had to access the rear blanking plate / bolts from L side (behind injector pipes) & below. The main trouble was getting the rear blanking plate & bolts off..just working with my finger tips. The DIY wire tool was used to help take out the original seal at the rear.
Note 3: picture this yoga position: balancing on the knees on the drivers foot step, arms in & around the fuel pump, butt in the air, tongue sticking out, lots of moans & groans :lol:
Post by francophile1947 » Mon Oct 01, 2012 9:02 pm
rhino-wayne wrote: Note 3: picture this yoga position: balancing on the knees on the drivers foot step, arms in & around the fuel pump, butt in the air, tongue sticking out, lots of moans & groans :lol:
I'm sure I've seen that position and sound track in some film somewhere :wink: :lol: :lol: :lol:
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Post by M 80NGO » Mon Oct 01, 2012 9:36 pm
Have you primed the fuel system at the filter with the lill hand primer ? also have you defo reconected any wiring that you disconected whilst replacing the seals ?
rhino-wayne
Post by rhino-wayne » Mon Oct 01, 2012 10:05 pm
M 80NGO wrote:Have you primed the fuel system at the filter with the lill hand primer ?
??? No, tell me more! pls what hand primer?
(didn't disconnect any wiring...but maybe I should check encase some came loose)
Thank you
M 80NGO
Post by M 80NGO » Mon Oct 01, 2012 10:11 pm
Under the drivers seat you'll see the fuel filter, on the top is a screw top, unscrew and pump until you can feel the pressure in the system, then tighten and turn her over :wink:
Post by Northern Bongolow » Mon Oct 01, 2012 10:13 pm
crack (undo) the injector pipes and it may help prime the system (cover the cracked pipe with a cloth or you will catch an eye full).
check that you havnt removed the supply to the lecky stop switch.
rhino-wayne
Post by rhino-wayne » Mon Oct 01, 2012 10:26 pm
Thx folks, will check & do tomorrow. [-o< .......bit dark out there now:evil:
lazyb5
Post by lazyb5 » Tue Oct 02, 2012 12:44 am
If you dont have a hand primer find someone with a pela pump its what i did. You need to make sure you have diesel at the pump, otherwise it cranks and cranks and cra... you found that already. Hopefully you will have a hand primer, I`m now looking to replace my non hand primer with a fully working one coz if you run out of fuel its easy to refil and prime.
Hope all that made sense its late and I found some wine :oops:
Simon Jones
Post by Simon Jones » Tue Oct 02, 2012 1:11 am
Majority of Bongos that I've seen are not fitted with the primer on the fuel filter assembly (or at least I've never seen one :) ).
Post by mikeonb4c » Tue Oct 02, 2012 8:41 am
Simon Jones wrote:Majority of Bongos that I've seen are not fitted with the primer on the fuel filter assembly (or at least I've never seen one :) ).
Ditto
321Away
Post by 321Away » Tue Oct 02, 2012 9:35 am
as stated have to wind it over for quite a while, usually with accelerator wide open as you've pretty much emptied the whole fuel system, but usually starts within 30 secs? did you relocate the key on the pulley properly? as i've seen it done before where the pump looks like its located but it pushes the drive pulley forward and isnt seated properly and as such doesnt run! did you have to make any adjustments to the crank/pulley position to get the pump located/in?
Julian
rhino-wayne
Post by rhino-wayne » Tue Oct 02, 2012 7:00 pm
:D =D> SHE'S ALIVE =D> :D :lol:
Thank you, folks! she's up and running again ...phew
All she needed was the fuel filter pump a-pumping! :roll: DUUUUHH , I've changed the fuel filter twice in the past but never realised that bit on top was a pump :oops: :oops: #-o , nothing to unscrew just push on top.
bit of a shake, cough, splutter, & off she went again :D
Thanks all for your helpful advice................no time for more forum posts..........................
:twisted: :D =P~ GOT TO GO DRIVE =P~ :twisted:
Post by mikeonb4c » Tue Oct 02, 2012 7:30 pm
rhino-wayne wrote::D =D> SHE'S ALIVE =D> :D :lol:
Great news that your monster is alive
...now go drive :D :lol: :lol: :lol: 8)
rhino-wayne
Post by rhino-wayne » Thu Oct 04, 2012 9:35 pm
Just encase some local folks are looking to buy fuel pump seals, I bought here:
DTM, Short Street, St Philips, Bristol, BS2 0SW
Bosch Part No. 2460 223001-000
x2 seals
Total cost: £3.38...
.........and some yoga moaning & groaning.
Now how much would that have cost at a garage!?
