Rear Heater Contols
David Edwards
Rear Heater Contols
Hi folks mine seem to have seized, as well as the sliders missing, is it much of a job to change the control panel in the space under the rear offside window, does anyone know is there a fact sheet or info on it anywhere. Havent seen any for sale anywhere so before I take the plunge and buy one I need to know if it can in fact be changed. Thanks.
Re: Rear Heater Contols
Hi Dave,
I've been in there & done that a couple of years back....
Not a lot can really go wrong with the mechanical side of the actual controller...??
But, depending on which slider has seized it could be the flap that has jammed in the unit.... Like maybe the unnamed heat temp control flap over the part number 61-A09???? Or something jamming the spigot mover control for said heat flap?? Part 61-A20. & not giving the controller full movement....?
