Climate control - no heat
Re: Climate control - no heat
Post by g8dhe » Tue Oct 30, 2012 9:10 pm
Ady, is Northern Bongolow on here, and his favourite breaker seems to be these people http://myworld.ebay.co.uk/bongobits4u2012/ no personal experience, yet but others seem to be quite pleased with what they have acquired!
Lincsbongo
Post by Lincsbongo » Wed Oct 31, 2012 8:59 am
Thanks Geoff,I'll give it a go
jaylee
Post by jaylee » Wed Oct 31, 2012 9:45 am
g8dhe wrote:I've been trying to imagine how on it could have been snapped off! Its not exactly in a place where a foot could kick it, nor does it stick out particularly far to get much leverage on it.
As to how to replace, really not sure, it might be easier to get a complete unit from a breaker and replace it as a whole, the entire heater box, especially given the violence that might have been applied to break the shaft in the first place, there may be further damage that your not aware of inside maybe - just a thought! Perhaps Ady's breaker of choice can do a unit at sensible cost ?
One theory is it hasn't been snapped off....?? Stay with me!! :idea:
At some point the front heater matrix may have been replaced/fixed & the flap assembly has been bundled back together the wrong way round....?
What you maybe looking at in the picture might not be a broken spigot bit, but the bit that sits in the hole the other side..?? I guess you wont know for sure until the heater housing is taken apart..... http://lushprojects.com/bongopartsmk2/c ... mgno=.html
I have seen a similar hash made on the rear heater flap where it was stuck on hot & i had to turn the flap over to get it to function properly!!! :wink:
Post by g8dhe » Wed Oct 31, 2012 10:57 am
In which case there should be a spindle sticking out the other side with a flat on it .....
Lincsbongo
Post by Lincsbongo » Thu Nov 01, 2012 9:37 am
Gents,thanks again for the good advice. I shall check whether it is in the wrong way round. Still more concerned I can't seem to operate the flap manually which means its jammed somehow.
I spoke to the guy at bongo bits for u and he looked at one whilst I explained the situation and he reckoned the dash needed to come out to get at the heater box!
Kev
jaylee
Post by jaylee » Fri Nov 02, 2012 1:32 am
g8dhe wrote:In which case there should be a spindle sticking out the other side with a flat on it .....
I wouldn't disagree with you there Geoff... :) Looking at the drawing its hard to tell.. I never had the front heater housing apart... If it has just sheered off..?? I would have thought the servo would have give up before the spindle broke, if the flap had jammed?? :-k
Post by g8dhe » Fri Nov 02, 2012 11:22 am
Yup it wouldn't be the servo that snapped it! My thought was a foot but I can't quite see how, or maybe it was replaced with a damaged one previously ... who knows...
