Mr 2alloys
Moderator: Ian
Mr 2alloys
Does anybody know if Toyota mr2alloys fit bongos five stud x 114 pcd
- Driver+Passengers
Re: Mr 2alloys
MR2 wheels may not have a load rating sufficient to be fitted to a Bongo??
Re: Mr 2alloys
No - the centre bore is too small - see http://www.alloywheelsinternational.com/TOYOTA.html
Re: Mr 2alloys
Thanks guys appreciate replies and info
Re: Mr 2alloys
I have some OZ MR2 wheels on mine. When I got them I realised the centre bore was too small but on closer inspection I found they had been fitted with spigot rings that were too small. After knocking those out I bought some correct ones from ebay and bob's your uncle.
- mikeWalsall
Re: Mr 2alloys
The only spigot rings I have seen are to reduce the diameter of the bore (hole in the wheel) .. be interesting to see how they are used to make the hole bigger so the wheel locates onto the hub ( spigot mounted) and not the 5 studs (stud mounted) ...
I have a nice refurbished set of five Toyota Lexus rims with a 60.1mm centre bore that will not fit onto the 'spigot lip' on the Bongos hubs ..
Re: Mr 2alloys
It sounds like the rings were stuck to the wheels rather than the hub, so just needed to be removed to open up the hole to the full size.mikeWalsall wrote:The only spigot rings I have seen are to reduce the diameter of the bore (hole in the wheel) .. be interesting to see how they are used to make the hole bigger so the wheel locates onto the hub ( spigot mounted) and not the 5 studs (stud mounted) ....
Re: Mr 2alloys
If removing the spigot rings opened the bore to more than 60.1, they probably weren't genuine MR2 wheels
Re: Mr 2alloys
I didn't think about that before posting, only that the guy I got them off said they came off his MR2. Sorry peepsfrancophile1947 wrote:If removing the spigot rings opened the bore to more than 60.1, they probably weren't genuine MR2 wheels
The spigot rings that were in there were made of aluminium. I didn't even realise they were in there. I had the wheels blasted and coated the colour they are now THEN realised they didn't fit. I was just about to smash everything to bits with a hammer in frustration when a mate took the hammer off me and knocked one of the rings out. The holes were then too big and I had to buy the new spigot rings to make them centre on the Bongo correctly
- mikeWalsall
Re: Mr 2alloys
Most after market rims are made to fit multiple vehicles .. that is why they are made with a over size bore so that spigot rings will 'down size' the bore to the correct size for a wider range of vehicles ..
