Our Freda has just been serviced and had it's MOT. It passed the MOT with no work required - not bad for a 17 year old van
The service was done after the MOT, the coolant was changed and the system bled. We were warned that our low coolant alarm might bip on the way home (as the engine was hot when the coolant was changed) and that we would need to check the level and maybe top it up in the morning.
On the way home from the service the temp gauge went quite high (approx 4/5ths of the way up when it's normally about 2/5ths). We stopped and panicked for a bit and tried phoning the garage but they'd all left.
As we were only about 3 miles from the garage, we decided to drive back and leave the van to be looked at again in the morning. However by the time we got back to the garage the temp was back to it's normal position. After a bit of deliberation we decided to drive home. We had to stop and top up the coolant on the way as the LCA bipped (it was below the alarm level but not below the low level) but we had been warned this might happen.
There were no further problems with the temperature, the gauge stayed in it's normal position for the rest of the journey.
I intend to check the coolant level again in the morning and will ring the garage before we drive the van again, but before I do this I just wondered if anyone could tell me if it's normal for the temp to go up a bit after a coolant change?
After all the cracked head posts we are a bit paranoid about the whole coolant system.
Thanks for your help.
Sara
