Hydrometer test
- AndAndDen
Hydrometer test
Could someone tell me please what the hydrometer should read after testing my antifreeze? Would be much appreciated if you could tell me in Simple terms. ( I have just bought one).Done 400 miles since i bought my Bongo,temperature gauge is running normal at about 11 o,clock. Big thankyou in advance. Andy
ferdyb
I seem to remember there are four possibilities.
1) is it ethalene glycol
2) is it methanol
3) is it cold
4) is it hot
depending on which of the above applies, you look at the temperature level on the float and read off the temperature - this is the freezing point of your coolant.
If you have a mixture of 1 and 2, it's anyone's guess !
ferdy
2) is it methanol
3) is it cold
4) is it hot
ferdy
Colin Lambert
Veg_Ian
Vanmanerik
Anti Freeze
No one answered the original question???????????????????????
Is there an answer in very simple terms if I am using ethylene glycol and the system is cold?
Veg_Ian
No because the specific gravity is dependant on temperature, viscosity, pressure and chemical composition
http://www.findarticles.com/p/articles/ ... i_n9401588
that's why I suggested chuck it out and start again.
Veg_Ian
Vanmanerik
Veg_Ian
Veg_Ian
