	Moderator: Doone
								kingbillybongo
						Post
								by kingbillybongo » Sat Jan 26, 2013 11:51 am
			Was looking for brackets and came across these for £90 .bolt on under d rings on aft roof and st steel.
Result.    A little adaption and I can fit my new fiamma pro 35 awning when weather improves.
Personally think they are better than the clamp on the gutter type.
Will let you how it goes if the snow ever stops?
									[color=#0000BF]billybongofreedom[/color]
								mort
						- Bongonaut
						Post
								by mort » Sat Jan 26, 2013 3:27 pm
								kingbillybongo
						Post
								by kingbillybongo » Sun Jan 27, 2013 12:07 am
			Yes,but these are an old link. These ones you have to fix in to the roof .the new ones you don't.they screw under the d rings which is much better.they don't do  these type any more that you have shown .rang and spoke to them and they sent me the link.
								alan
						Post
								by alan » Sun Jan 27, 2013 2:28 am
			how  are going to  fit the por35 to these  can see how the 45 it /s wold but  lookig at the 35 fitting looks diffent
 asking cuse there was a other post  not long ago about how to fit 35  we got a 45 s fitted with brigewater matel caft fitting  like the ava ones but come in two parts and dont bloke the gutter  easy to fit as well
									take it easy drive a bongo
								kingbillybongo
						Post
								by kingbillybongo » Sun Jan 27, 2013 9:39 am
			alan wrote:how  are going to  fit the por35 to these  can see how the 45 it /s wold but  lookig at the 35 fitting looks diffent
Using a 3m Rrail made by fiamma across the top of brackets and cut to length.maybe make some plates up if needed but it looks like I won't need them! Simple to adapt to fit pro 35 mounting.
								alan
						Post
								by alan » Sun Jan 27, 2013 9:48 am
			kingbillybongo wrote:alan wrote:how  are going to  fit the por35 to these  can see how the 45 it /s wold but  lookig at the 35 fitting looks diffent
 then you might want to give brigewater matel caft ltd a ring then there braket work the same way as the ones your looking at  but come in to parts the cruved bit that bolts on to the roof  the same but then a flat plate  to the face an fit in the gutter.
ps  from other  on the here  if yours is   a Aft bongo these well fit( both  one  )but not on  a tintop conversion there say roof shape diffent
								19exotic
						- Apprentice Bongonaut
						Post
								by 19exotic » Sun Jun 23, 2013 11:03 am
			Billy,
Any chance you can post some pix of the F35 fitted & how the brackets look?  Also how they need adapting to fit.
Looking at getting this awning+kit but need to know how much work is involved & also want to see how it looks aesthetically on the van.
Thanks.
Don't let your dreams be clouded, aim your sights high, search your true feelings and Reach For The Sky
								kingbillybongo
						Post
								by kingbillybongo » Sun Jun 23, 2013 1:17 pm
			Will do. At the bash at mo. if your here come have a look
