'heat' warning light remains on - petrol engine
[email protected]
Post by [email protected] » Mon Feb 04, 2013 7:33 pm
The 'heat' light on the right hand side of our dashboard remains on when the car is on.
We did have a similar thing with the airbag light a year or so ago (that the mechanic dealt with by disabling the warning light rather than fixing the airbag). As such, I am wondering whether it is the electrics rather than a real error but would like some reassurances or suggestions as to what could be at fault.
Jamie
mikeWalsall
Re: 'heat' warning light remains on
Post by mikeWalsall » Mon Feb 04, 2013 7:50 pm
"Disabling the warning light rather than fixing the air bag".
Be careful .. that maybe a failure he next time you take it in for an MOT ..
Simon Jones
Post by Simon Jones » Mon Feb 04, 2013 9:14 pm
What sort of engine have you got?
As Mike says, removing the airbag light is very likely to result in 'reason for refusal' of an MOT certificate under the new regulations. At the end of the day, the airbags are there to reduce injury or save a life in the event of an accident so need to be in working order. :shock:
New Forest Terrier
Post by New Forest Terrier » Tue Feb 05, 2013 12:29 am
Must be a petrol V6 or 2ltr with a heat warning light. This is a catalyst or lambda sensor problem. It is possible but rare to have a warning light problem and then the light is usually intermittent due to bad contact.
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
mikeWalsall
Post by mikeWalsall » Tue Feb 05, 2013 2:13 am
