removing rear speakers
Moderator: Ian
lancyman
Post by lancyman » Tue Apr 09, 2013 9:54 am
Hi All,
I have some new speakers on the way for the front and rear of the van.
I have searched, but I can't spot how you remove the rear speakers.
I tried leavering them off with a screwdriver last night but no joy.
Any help would be appreciated.
Thanks.
rita
Re: removing rear speakers
Post by rita » Tue Apr 09, 2013 10:14 am
Hi,the covers do not come off (not meant to come off)you need to remove the complete panel trim.
Does the vehicle already have rear speakers fitted.
lancyman
Post by lancyman » Tue Apr 09, 2013 11:06 am
I don't know yet to be honest. Need to get the real panel off tonight.
Assuming speakers arrived. Is it a nightmare if it doesn't have them already?
Simon Jones
Post by Simon Jones » Tue Apr 09, 2013 1:23 pm
Depends: if the speakers are missing, the wiring often is too.
rita
Post by rita » Tue Apr 09, 2013 1:31 pm
lancyman wrote:I don't know yet to be honest. Need to get the real panel off tonight.
You Might be able to see if there are speakers/wiring if you remove the wee tray thing and shine a flash light through the hole.
I think the rear speaker wiring (if fitted)should be visible from under/around the centre console,Geoff will probably advise.
Hanksy
Post by Hanksy » Tue Apr 09, 2013 2:15 pm
don't worry if there is no speaker wires, its an easy run from the stereo to the rear panels via the center console and under the carpet
lancyman
Post by lancyman » Tue Apr 09, 2013 2:43 pm
Thanks all, I will have a look later. Really hope I already have some speakers in.
However, I reckon even I can run a wire through the console etc. Cheers.
jaylee
Post by jaylee » Tue Apr 09, 2013 8:06 pm
The odd thing about my van was although there were no speakers in the back, or even the brackets & no evidence they were even fitted in the first place. The speaker loom & plug was there!!
chris40taylor
Post by chris40taylor » Wed Apr 10, 2013 11:56 pm
Hi, I have just fitted a new stereo and thankfully whoever had it before me had already fitted an iso connector. The old stereo was a Sony and they had fitted an adapter to fit it which i just removed allowing the straight plug to the iso.
My problem is my rear speakers have never worked. When I bought it three years ago the chap mentioned something about it but i have long since forgotten why he said they weren't working. The correct coloured wires appear to be there at the iso connector and in the right place. I have looked into the rear outer cover of the speaker and I can see some sponge covering. Does this mean there are actually speakers in there or is this the reason for no rear sound, there aren't any??
Oh, and how do you get the plastic tray above the stereo off. When i had the stereo out i could not seem to find a clip to release it and did not want to pull too hard and break it.
Any ideas?
Chris.
Last edited by chris40taylor on Wed Apr 10, 2013 11:59 pm, edited 1 time in total.
chris40taylor
Post by chris40taylor » Wed Apr 10, 2013 11:57 pm
Sorry, mine is a 1995 2.5td auto.
Hanksy
Post by Hanksy » Thu Apr 11, 2013 10:41 am
chris40taylor wrote: Oh, and how do you get the plastic tray above the stereo off. When i had the stereo out i could not seem to find a clip to release it and did not want to pull too hard and break it.
Any ideas?
Chris.
i just pulled mine and broke it now its really easy to get in and out :mrgreen:
chris30taylor
Post by chris30taylor » Thu Apr 11, 2013 1:56 pm
Very good.
:lol: =D>
David Edwards
Post by David Edwards » Thu Apr 11, 2013 3:47 pm
my rear nearside speaker is not working, been meaning to do it for ages but havent got around to it yet,lol, might have a go soon
jaylee
Post by jaylee » Thu Apr 11, 2013 9:01 pm
Any ideas?
Chris.
As you may have found out.., :lol: There should be retainer clips either side of the 1 din unit.. I just removed the glove box & put my hand up to unclipped & push out the one side then jiggled & pulled it forward. :D
lancyman
Post by lancyman » Tue Apr 23, 2013 9:59 pm
So the saga continues. All four speakers in.
Working ok, then.... Nothing. All four gone off.
No idea what's happened. Any ideas good people?
Return to “Pimp My Bongo”
