sun canopy
Moderator: Doone
sun canopy
I have been looking for a well priced canopy.
I have an awning but fancy one of these also for if the sun actually comes out.
any recommendations?
i have just found this website. they look rather cute. and the website says they are suitable for bongo's too. Anyone got one ?
http://www.the-bus-shelter.com/index.html
vicki
vicki
Re: sun canopy
I've got something similar I bought in sept never used it yet but very similar attaches with figure of eight strip
- Driver+Passengers
Re: sun canopy
I bet a few folk will have tried tarp-type awnings. I can't offer you any experience but I'm about to try out the idea...
The Bus Shelter looks good, but I'd just make one up.
You could splash out on something like this... http://www.ddhammocks.com/product/ddtar ... _brown_3x3. Then get a couple of 4'-8' washing line props from Home Bargains (£3 each), figure-of-eight strip, gutter clamps or something (£10-ish), £1shop (or spare) guy lines and tent pegs, and you'll still come in around £50, and that's with a decent, versatile tarp - shave £30 off that for a cheapo. I've got a Rainexo on order (3mx2m, £10)... triple laminate, comes in three weights, meant to be quite tough - hopefully quiet, too.
Re: sun canopy
Hi - I use a standard tarp and attach it to the hooks which are under the AFT using these and guy it out with cheap poles
http://www.uktarps.com/hold-on-clips
These are brilliant - grip the tarp anywhere and have never come undone - the tighter you attach them the tighter they grip.
Re: sun canopy
I quite like the look of these. £80 though (hence why I haven't bought one yet)
http://www.outdoormegastore.co.uk/outdo ... wning.html
James, Jo & Erin
JAL/V6/LPG/Mushroom/Full Side Conversion/Cannon Forge Bed
- Driver+Passengers
Re: sun canopy
I like the fact it's got a window! Good to keep an eye on the kids, etc...jojay5 wrote:I quite like the look of these. £80 though (hence why I haven't bought one yet)
Re: sun canopy
I have used off the shelf tarpaulins with poles and guys borrowed from my Easycamp Daytona when stopping just for one or two nights. I have even used a spare awning rail as a centre pole to give added headroom. All perfectly adequate for an overnight stop.
However one unkind person did remark that I had made a nice campsite look like a refugee camp.
He is a "glamper" type so water off a ducks back.
Re: sun canopy
We've got the older version of this (which wasn't £80) and learned a valuable lesson. Don't let rain pool on the roof and don't leave it to its own devices in high winds with several kilos of rain sitting on it.Driver+Passengers wrote:I like the fact it's got a window! Good to keep an eye on the kids, etc...jojay5 wrote:I quite like the look of these. £80 though (hence why I haven't bought one yet)
You'll bend your poles
It's actually a very handy bit of kit but I don't think I'd pay £80. See if you can get one cheaper (someone may even stock the older style which has bigger windows).
Alison
Re: sun canopy
thanks for all the replies.
i still like the look of the 'bus -shelter' canopy i mentioned.
i emailed the company and they were quick to reply with advice
will keep you all posted
v
v
Re: sun canopy
i use the kyham sun canopy.
check their store out
good in the sun just not the best in the rain as can fill up. hence the name though.
luke
luke
Luke (V6 and LOVING IT)
- Driver+Passengers
Re: sun canopy
To stop water filling up a tarp on top, get an extendible washing line prop then cut a hole in tennis ball and pop it on top. Use that to prop up the tarp in the middle. It might fall over in wind, but should otherwise be held down in place by tarp tension.
Re: sun canopy
i have a bus shelter -it was called something else and came from funkyleisure.com but it definitely the same thing but much cheaper than £80 but a couple of years ago so it may have gone up.you could buy the bits you needed separately so i didnt need to add the figure of 8 or the lines or the pegs which cut the cost down. i had them from the awning.The reason i got it was because i couldnt manage the awning on my own -
This is very simple to put on and quick -funky leisure do tell you not to leave it in the upright position unattended, Their poles are telescopic so you can just lower them to let the rain run off rather than pool I take it down in windy conditions but then the very expensive roll out ones get taken down in wind too.I like it i love the colors but it really is a fairweather thing and in terms of shelter and stability in gales and snow doesnt compare at all with the khyam awning.
I wanted a windbreak to put round as well but am still looking for one which matches the look -i am now considering dismantling the old grey one and replacing the fabric with cheap flowery shower curtains just in case anyone cant see my bright orange bus shelter
Re: sun canopy
Hopeless in the wind, including a day with puffy clouds and thermal gusts. Makes it hard to leave it unattended unless very well secured and/or parked in a very sheltered spot. But quick to put up and take down so maybe that doesn't matter.
Re: sun canopy
Obelink do some interesting tarps/awnings. (Google/Chrome will translate any reviews)
We've used one free standing in some baking hot weather (must have been a year or two ago...)
They could probably be attached to a bongo with a pole and clamp kit (http://www.khyam.co.uk/detail.asp?p=460.
Re: sun canopy
took the plunge and ordered one from the Bus Shelter company.
will let you all know what it is like when it arrives.
v
v
