windscreen wiper won't park
entity
Post by entity » Tue Apr 23, 2013 12:22 pm
Hi all, my front windscreen wipers don't work on Intermittent and won't park. is there a relay? and if so where ? or is there some other reason for the problem. My MOT is due soon and i have been told it can fail if the dont park.
thanks Dave
teenmal
Re: windscreen wiper won't park
Post by teenmal » Tue Apr 23, 2013 2:03 pm
Hi, does the wipers and washers work and park when you pull the stalk towards you?
The intermittent wipe functionis not part of the MOTT.
entity
Post by entity » Tue Apr 23, 2013 4:37 pm
Hi the washers work but not the single wipe when i switch the wipers on to slow and fast speed they work as normal but when i move the stalk to switch the wipers off they stop dead, wipers half way up the window. They need to park for MOT.
teenmal
Post by teenmal » Tue Apr 23, 2013 4:45 pm
entity wrote:Hi the washers work but not the single wipe when i switch the wipers on to slow and fast speed they work as normal but when i move the stalk to switch the wipers off they stop dead, wipers half way up the window. They need to park for MOT.
lHi,some WW motors have a sensor fitted for park,.(a type of overrun Geoff might be able to help .
Post by g8dhe » Tue Apr 23, 2013 5:47 pm
There isn't any relay involved circuit below;
Most likely will be contacts in the switching module, the intermittent operation is via a small electronics timer not fully shown on the above diagram.
jaylee
Post by jaylee » Tue Apr 23, 2013 8:54 pm
Hey guys! Does this diagram on the link look familiar?? :idea: Check out pages 78 to 81... This may help diagnosis?? http://www.autoshop101.com/forms/maz-ewd.pdf
Velocette
Post by Velocette » Tue Apr 23, 2013 10:25 pm
g8dhe wrote:There isn't any relay involved circuit below;
Wracking my brains back to a Practical Electronics intermittent wiper controller I made once for my old Austin 1300, the intermittent circuit made use of the constantly energised park circuit in order to function. If that is how they do it with OEM intermittent wipers it would explain the loss of both functions together.
rita
Post by rita » Wed Apr 24, 2013 10:21 am
The self parking mechanism is normaly located in the wiper motor,the old type had an adjustable cap/contact to position the arms/blades.I think the newer ones will have an inbuilt sensor.It would worth checking and cleaning the plug first.
entity
Post by entity » Thu Apr 25, 2013 12:59 pm
Hi all, thanks for your input i have checked plugs had motor off and wiper stalk off still can't find out the broblem, do you think i need a new motor?
