Hi Folks I've had the LB on charge overnight with a regular type of charger. I have disconnected both leads. The meter on the charger has gradually gone down towards 1 but not quite there yet.
I would like to know if the inbuilt charge indicator on the battery is reliable or not. It used to show 'green' at all times. I have had some residual drain but that is now cured. My multi meter (volts) is reading 13.8 after a rest period so, how will I know if it is full?
Pete
Battery charging
Moderator: Doone
Battery charging
My iPhone - My office
Re: Battery charging
13.8v after a rest period (at least 5 mins) is full. The colour indicator in the battery is physical - it depends on the chemical state of the electrolyte - so it can't lie - unless it gets stuck - it is a floating object.
Thanks Dodgey, when on site and using the Lidl smart charger which I have 'hard wired', would it be best to take off one of the main leads? I suppose the same question would apply to a solar setup.
I'm not sure what you mean by on site - do you mean hooked up to mains? Does your van have a Zig unit or similar?. It depends on the other electrics in your van. But... in all cases....
- Solar - regardless, always leave it connected - it charges your battery and does not drain it.
- Lidl charger - if you leave it connected to the battery then there is probably little to no drain when it's powered off. Can't do any harm.
I meant on hookupDodgey wrote:I'm not sure what you mean by on site - do you mean hooked up to mains?
No, Big LB and Willinton kitDodgey wrote: Does your van have a Zig unit or similar?.
Not sure what you mean by thisDodgey wrote: It depends on the other electrics in your van.
I never thought that the charger could caause a drain would this be even when turned off at the mains and unplugged? I know I have been loosing charge in the LB but thought it was the Chinese head unit.Dodgey wrote: But... in all cases....- Solar - regardless, always leave it connected - it charges your battery and does not drain it.
Ahh - I see why you want to know if you should remove one of the main leads when the battery is full - the answer is no. Both your Lidl charger and your solar charger will step down to trickle charge when your battery is full. This is a good thing and better than switching anything off. They won't "over charge" your battery.
p.s. some chargers have LEDs/displays that are powered from the battery they were charging and can drain the power a little when the mains is off.
