I've just had a service and since then when I first start it up from cold (after being left for a day or two) the RPM is all over the place, lots of shaking.
My mechanic thought it may be a dud fuel filter leaking air so he replaced it with another, still the same.
Is this just a coincidence or something he has done?
Here's a video to what's happening....
http://youtu.be/WFH_aay1VIs
Thanks in advance Jim
Hunting Tickover when cold
- jimpearceuk
Re: Hunting Tickover when cold
Msg posted on Youtube
- jimpearceuk
Thanks Marc not tried that.
Funny you should say that as I also had a pipe burst just after the service and had her recovered to the garage, yesterday I went to put the heater on while driving and I didn't get any hot air until the climate control got to the top temp, 31deg I think it is??
When I turned it down it seemed to be OK, thought the flap may be stuck.
Will try Thursday when I get home and report back
Cheers again Jim
Cheers again Jim
- jimpearceuk
Tried that no difference but I do still have the heater issue. I only get hot air from the highest setting on the climate 31 - otherwise the air is cool. Does seem odd that both issues happened at the same time.
Anyway to check / replace the heater solenoid? is it a big job?
Thanks Jim
Thanks Jim
