Three radiators at the front???
				revjhdavis
 - Bongonaut
I was doing some work at the front of the van and realised that there are three radiators under there....the front one is presumably the air-con, then comes the water radiator, and then a smaller one at the bottom (behind the other two) with its own air scoop - is this associated with the auto gearbox?
Re: Three radiators at the front???
It's the inter cooler.2-5tdi
				revjhdavis
 - Bongonaut
Ah yes....I understand now.  Thanks for that.
You may also find a 4th one if you have a transmission oil cooler as well.
						- mikeWalsall
The auto gearbox cooler is built into the bottom of the engines radiator...
Ahh yes - I knew it was there somewhere, with an extra pair of hoses.mikeWalsall wrote:The auto gearbox cooler is built into the bottom of the engines radiator...
- mikeWalsall
No need to be sarky.. I posted at the same time as you ..
But there again .. what constructive use was yours ..???
Can't see anything sarky - just a harmless notation that suggested he knew because of the two hoses.
						- mikeWalsall
Ahh right .. sorry .. I assumed the the original poster was after information ..
cheers - some times assumptions work out but asking questions will always helpful and avoid uncertainties or assumption - the moral of the story being if in doubt ask
