It shouldn't boil at 106 in the engine, surely the pressure pushes the boiling point further up again?hijimhere wrote:Not to sure about what temps that thermostat open/close - my experience suggests that thermostats are fully opened @ 98 degree and boiling point with a good 50/50 mixture is 106/107 degrees. Maybe it was a stuck thermostat. Has it happened again?
I have seen 104 on my Tm2 just after cresting a considerable mountain in Spain and it went straight back down again. if I had stopped at that point it might well have gone on to overheat dueto heat soak (IMO). Mine has had a new head a couple of years ago and also new rad, pump, stat., etc. IMO I wouldn't push a Bongo that hard that had an original head gasket and radiator and was 18 years old.
My sensor is on the back of the head as recommended by Haydn.
