2ltr petrol damp start problem
DILLIGAF
Post by DILLIGAF » Sat Feb 15, 2014 4:31 pm
my van runs great when its dry but it doesn't like the wet weather, i have dried all the electrics and sprayed with "WURTH ultra 2040" and it will be ok for a while, then just when you could least do without it, it refuses to start again until everything is dried out and sprayed again! any advice will be gratefully received.
being a philosopher, i have a problem for every solution.
Simon Jones
Re: 2ltr petrol damp start problem
Post by Simon Jones » Sat Feb 15, 2014 4:50 pm
Are you able to pinpoint which part of the system is causing the problem? On the V6 there is a seal under the dizzy cap which could be a weak point.
DILLIGAF
Post by DILLIGAF » Sat Feb 15, 2014 5:11 pm
Thanks Simon, i will take a better look at that tomorrow and see if that is the problem, it's just having some dry weather to be able to get out there would be nice, i can't get the bongo in my garage where its dry to work on anything. If this weather keeps up i'll be fitting floats and a sail! all the best, Brian.
