Hi guys, can anyone tell me what length the Khyam Motordome apron Bead is?
Tony
Length of a Motordome Apron????
Moderator: Muzorewa
thedogsbollox
- Tribal Elder
thedogsbollox
- Tribal Elder
Re: Length of a Motordome Apron????
Was hoping someone knew the exact dimension. The problem is that when it was on the bongo it was slightly longer than the figure 8 strips and the strips were 3 pieces. The ends of the beading kept creaping out of the figure 8 and over time splayed the end a bit. My idea is to get a bit long enough to span past the bead so the end of the bead is well inside the figure 8. And there is no drips from joins. I can get a 2.5m length of figure 8 but wondered if it was long enough to be longer than the bead. If not then I will get 3 smaller lengths and put up with the drips.
There's always a tape measure
thedogsbollox
- Tribal Elder
Yes there is. My motordome is buried under a mass of camping gear and didn't really want to disturb it. Was kinda hoping somebody faced the same problem.
You could try Khyam's technical helpline: 0844 850 4401
