Visual LCD battery display.
Moderator: Ian
Gixermark
Post by Gixermark » Sat Apr 05, 2014 4:31 pm
Just a quick project :
Cost less than £3 each from China via eBay ...inc postage! Checked the voltage via a voltmeter and they are accurate.
Dremelled the holes to fit, removed the centre console to do this. Wired direct to each battery via a fuse and the double switch down by my left knee. Now we know exactly what voltage the battery's are via a quick glance, they can be turned off when not required.
A cheap, easy thing to do ....took about 2 hrs to do all in.
Re: Visual LCD battery display.
Post by Bob » Sat Apr 05, 2014 5:37 pm
Just got one of these little jobbies to monitor the LB in the caravan, £2.60 inc delivery.
Great deal. :)
winchman
Post by winchman » Sat Apr 05, 2014 6:51 pm
Excellent
Simon Jones
Post by Simon Jones » Sun Apr 06, 2014 12:22 am
Ah, so that's what you wanted that trim panel for ;). Very neat looking job.
Gixermark
Post by Gixermark » Sun Apr 06, 2014 5:46 am
Simon Jones wrote:Ah, so that's what you wanted that trim panel for ;). Very neat looking job.
Darn it ..you got me there Simon! :D
Yeah, cut the original hole on the bottom right but when I tried to re-fit it, it was touching the metal plate behind so wouldn't fit flush. Fussy bugger, hence the SOS for a new panel..... :lol:
rockerbox
Post by rockerbox » Sun Apr 06, 2014 8:59 am
Very neat.
Have been trawling Ebay for one but can't find them. Any chance of a link please?
Gixermark
Post by Gixermark » Sun Apr 06, 2014 9:06 am
rockerbox wrote:Very neat.
Item ref : 221298249683, cost £2.37 each inc postage from China ( how on earth they make any money is beyond me! ) you can get different colour displays if you use the "find items like this" tab :D
rockerbox
Post by rockerbox » Sun Apr 06, 2014 9:47 am
Thank you :D
somaRich
Post by somaRich » Thu Apr 10, 2014 4:41 pm
Just fitted my Volt/temp/clock drilled a little hole in the cubby above the stereo, I now need to wire in a switch to choose between leisure and starter batteries.
Only £5 here:
http://www.amazon.co.uk/NuoYa005-Temper ... ar+voltage
bongojoe
Post by bongojoe » Fri Apr 11, 2014 3:14 pm
Any excuse to show off my Bongomaschine!
Full details here. (Took a little longer than two hours...)
1999 2WD 2.5L Diesel AFT
Driver
Post by Driver » Sat Apr 26, 2014 6:47 am
Would you consider making / producing and selling these Digital Gauges sure there would be lots of buyers.
Looks really good .
Andy.
Mazda Bongo Aero 2 ltr Petrol White 2001
notlob
Post by notlob » Sat Apr 26, 2014 10:34 am
Probably missing something here?
Whilst I think this is a great idea and fancy trying it out, doesn't the position mean that its difficult to move the central console when carrying out maintenance, etc?
Dave
Gixermark
Post by Gixermark » Sat Apr 26, 2014 11:28 am
notlob wrote:Probably missing something here?
Dave
No Dave!
The LCD's take very little room, the wiring has two quick release connectors so you lift the console as usual, unclip the connections and remove... Simples!!!! ;-)
notlob
Post by notlob » Sat Apr 26, 2014 4:27 pm
Ahhhh, I was missing something!!
Dave
cavey
Post by cavey » Sat Apr 26, 2014 10:50 pm
somaRich wrote:Just fitted my Volt/temp/clock drilled a little hole in the cubby above the stereo, I now need to wire in a switch to choose between leisure and starter batteries.
Only £5 here:
I've got one of these tool although I find that the voltage reading sample interval is far too frequent (meaning it's flickering between fractions of a v all the time). Also slightly dubious temperature reading, but maybe thus is due to where I located the sensor. Still like it though. Just wish it could be a green backlight rather than the choice of blue or orange! Cheers, Dave.
Return to “Pimp My Bongo”
