V6 oil leak
V6 oil leak
I have a Ford Freda V6 which has developed a misfire...after checking the HT leads I have found oil in both the os and ns end leads...does this sound disasterous or is it an easy repair..I am also on holiday and need to tow my caravan home is this advisable....
Re: V6 oil leak
they often seem to leak from rocker cover gasket
check all bolts are tight
in the end might need new gaskets
Re: V6 oil leak
Managed to soak the oil up and dry out..rocker bolts were loose.....now tightened leads clean and dry..no misfire... will run today and recheck...fingers crossed....many thanks..
Grahame at work
Re: V6 oil leak
you should note that the rock cover bolts only require a bit more than finger tight to meet the spcification as they have rubber seals on each one that will break if over tightened.
Regards Grahame
Regards Grahame
