Anti-roll bar
Anti-roll bar
As a non technical 1997 Bongo owner, I would be grateful for advise following recent MOT - Advisory info showed that both sides of rear anti-roll bar had 'slight play in a pin/brush'. Should this be done soon as I will be driving around festival muddy fields with a fairly heavy load over the summer? If so what parts are needed and how much is it likely to cost at my local garage to have the work done? Thanks!
Re: Anti-roll bar
get them to do the lot
2x ubrackets ...2 bolts each
2x rubber bushes held be the above
2x drop links 2 bolts each
should not take 45 minutes
main problems getting them undone,shearing them off
would help to spray with wd 40 some days before going to garage
Re: Anti-roll bar
Thanks - great help!
