Major Service
Post by mikeonb4c » Mon Jan 08, 2007 10:58 pm
Wouldnt have a clue how to back of the injectors - my nearest experience was working on SU carbs 30+ years ago!!
The ari bleed screw is on side of the filter housing at the top of the filter housing, next to one of the fuel pipes - you cant miss if (from memory) as its is the only screw in town :oops: :oops:
dandywarhol
Post by dandywarhol » Tue Jan 09, 2007 12:36 am
cezeta wrote:where is the bleeding screw mike, i used the old fashioned way of backing off the injectors and bled them like a domestic radiator. if there is a bleed screw then that would be better.
I had a chevy van and that had what looked like a tyre valve along one of the pipes, i took the cap off and pressed the valve. it wisted and farted then spat petrol on me. started perfectly after an overnight stand after that.
If you fill the new filter with fresh diesel (or better still, half diesel/half diesel injector cleaner) and refit it there's no need to crack them back or bleed the system :)
