Traced a water leak to the thermostat area, dripping either from joint between cover/case or somewhere in that vicinity.
Any known problems in that area so I can give the mechanic a heads up on what might need replacing?
water leak from thermostat cover/case
Kevin Thomas
Bongo + Caterham = miles of smiles
Re: water leak from thermostat cover/case
gasket as such is on either side of themostat
suggest order origimal from a mazda dealer
other than that its the hose or its clips
it will need bleeding get him to watch 3x youtube videos
