Front heater fan not running
mareng
Post by mareng » Wed May 07, 2014 1:03 am
Just wondering if anyone can guide me in how to remove the front heater fan on a 1996 diesel Bongo. The fan spins by hand but will not switch on. ( brushes?).
The resistor appears to be ok.
Is it easier to remove from underneath?
wonkanoby
Re: Front heater fan not running
Post by wonkanoby » Wed May 07, 2014 4:14 am
you do it from above
there is a faq if your a member
its a few bolts and screws and a couple of electrical connectors,one in passenger footwell
helen&tony
Post by helen&tony » Wed May 07, 2014 7:07 am
As Wonkanoby says...if you are a member, there's a guide available...It's in the "Fact Sheets" under "Heater Fan Repair"....easy job...15 minutes or so to get the fan out
Post by Northern Bongolow » Wed May 07, 2014 9:37 pm
is it off at all speeds, or does it work on some.
if the fuse is ok then check the lecky plug, this gets a bit of weather abuse, its just in front of the heater fan unit just behind the rad. pull the plug apart and see if its a nice green colour.
