Got a slight squeak at idle, it dissappears when the revs are increased just slightly.
My money is on loose belts or water pump bearings.
Anything else I should be considering.
Slight Squeak At Idle
Mark Elvin
- Tribal Elder
Re: Slight Squeak At Idle
Probably the belts. There are two for the alternator and one for the A/C. Check the tension and if ok, it may be worth replacing all of them especially if they look past their best. If you get a squeak under load it's often the no.1 exhaust manifold stud that's come loose or snapped off.
Mark Elvin
- Tribal Elder
It was the belts. Nipped them ip this morning and noise gone.
