Got the air con done (at Kwik Fit) and I... by chance... passed by my local garage (not bongo conversant) and asked if they had any spare wheel nuts hanging around cause one is missing. Then mechanic comes in and says I think it needs more than wheel nut mate it's pissing water out....
So I go out and look and he puts finger in and smells it and say yep.... thats water from your engine.
So I am thinking can air con recharge mess engine up??? I would have thought not.
I have booked it in with them and will have to make sure they know about the bleed procedure.
Is there a point by point bleeding procedure guide in members area that I can print out and give the mechanic ?
I will have to trust the local garage to do it cause the bongo conversant one is too far away and I fear a severe overheat running it more than the 1/2 mile to the garage from cold.
I know you have to do reg maintenance but feeling a bit dejected at the mo.
