engine oil
engine oil
Simple question folks looked in the manual but I cant seem to find where to top up the engine oil in my 2.0 litre petrol 2000 model, I know where the dipstick is but not the filler cheers
prior owner of >>>>1999 2.5 diesel ex tin top &FORD FREDA 2000 2.0 LTR PETROL
- mikeWalsall
Re: engine oil
- Muzorewa
Re: engine oil
It's on the other side under the driver's seat
On the diesel the dipstick & filler are both on the same side. On both petrol models they're on different sides as the engines weren't specifically designed for Bongos. On a normal motor once you've opened the bonnet, it doesn't matter which side the dipstick & filler are on.
Re: engine oil
cheers does it hinge back like the passenger side as i have a side conversion right up to the drivers seat. ok sorted cheers
Re: engine oil
Sometimes, if accessibility is tricky, it can be better to remove the seat which is only held in place with 5 bolts and one connector to disconnect.
- mikeWalsall
Re: engine oil
On my V6 with a side conversion .. I tip my seat back as far as I can .. then prop it up with a peice of wood (bottom left in pic.) ..
