Washer pump
Nutcase
Washer pump
Post by Nutcase » Mon Jul 28, 2014 2:16 pm
Hi guys my washers have stopped working but when power put to pumps they work and all fuses seem Ok, which is the actual washer pump fuse, any help or advice would be a great help.
Gasy
Re: Washer pump
Post by Gasy » Mon Jul 28, 2014 5:03 pm
Blocked spray nozzles or water tubing is blocked
Blow it through
Re: Washer pump
Post by francophile1947 » Mon Jul 28, 2014 5:37 pm
There's a fuse fact sheet in member's area 8)
Gasy
Re: Washer pump
Post by Gasy » Mon Jul 28, 2014 5:43 pm
Fuse 13 is rear wipers and wash
Fuse 15 is front wipers and wash
Start top left
In fuse box next to drivers knee
So if your wipers are working it's not your fuses
Simon Jones
Re: Washer pump
Post by Simon Jones » Mon Jul 28, 2014 6:42 pm
Compatible direct replacement pump can be bought for under £10. Plenty of info and examples via the search facility.
Nutcase
Re: Washer pump
Post by Nutcase » Wed Jul 30, 2014 1:55 am
Cheers guys, I'll check them out this weekend, thanks
Re: Washer pump
Post by Northern Bongolow » Wed Jul 30, 2014 8:01 pm
test with a test light to see if there is live at the plug when washers pressed, if yes then it maybe an earth fault, these are found just at the side of the headlights,look for 2-3-4 wires going into a block that is bolted to the front panel, could just need a clean as they are a bit in the weather zone.
