Pressure testing - head gasket gone - help!
Gasy
Re: Pressure testing - head gasket gone - help!
Post by Gasy » Fri Aug 01, 2014 6:04 pm
Do you have brake down cover
AA or the like
Marbleous
Post by Marbleous » Fri Aug 01, 2014 6:29 pm
Yep - but it is still at the garage.
Gasy
Post by Gasy » Fri Aug 01, 2014 6:34 pm
Get them to transport it to a bongo garage
Might have to pretend you just broke down there and then
Marbleous
Post by Marbleous » Fri Aug 01, 2014 6:43 pm
But there isn't a bongo garage in about an hours radius!
Is there anyone in Cambridge who can recommend a garage?
Vicky
Gasy
Post by Gasy » Fri Aug 01, 2014 6:48 pm
Check your policy
I don't think that is a problem
I know If I brake down they will take me home or to a garage of my choice
Simon Jones
Post by Simon Jones » Fri Aug 01, 2014 6:49 pm
They say it went up to 25 psi? That's 1.7 bar and the cap on the header tank is rated at 1.1 so I would expect you would have coolant peeing out which doesn't seem to match the symptoms you describe. Personally, I would get it to a Bongo friendly garage for a second (and possibly more informed) opinion.
There is also a mobile mechanic who advertises on the forum who is highly recommended and may at least give you some free advice over the phone even if he is a bit out of your area.
Marbleous
Post by Marbleous » Fri Aug 01, 2014 8:40 pm
Between everything that has been said on the forum, what I have seen and what a mechanic friend has told my OH on the phone and how the garage was acting - I think they were either trying to pull a fast one - or are wrong in the diagnosis.
I'm going to sleep on it and decide my course of action in the morning - anymore advice gratefully received!
Thanks for your advice, particularly Roo.
Vicky
Post by Bob » Fri Aug 01, 2014 9:18 pm
Often it isn't someone trying to 'Pull a fast one' but that most dangerous of things, the things we don' t know that we don't know.
All to common with garages and Bongos.
If the nearest BF garage is 5 hours away it will be less hassle than 20 local garages who 'Learn' at your expense
I will again suggest BF might know.
New Forest Terrier
Post by New Forest Terrier » Fri Aug 01, 2014 10:20 pm
A little knowledge can be very dangerous with a Bongo. As well as a diagnosis the coolant has to be bled after a head replacement and further damage can be caused by an airlock. Any garage considering steel seal is not to be recommended. It does a lot of damage and while it can be used to patch up an old car for a bit more life, it is not for what was probably an expensively purchased camper.
Every bongo garage has stories of Bongos being towed in with a diagnosis of head gone where it is a far less serious problem. If there is no Bongo garage in your area, is there a Mazda one who might be familiar with the beast? They might have the knowledge to give you a correct diagnosis.
Find your nearest rated Bongo seller and give them a ring to see if they can recommend anyone. If all else fails find your nearest Bongo specialist, check that they can handle a V6, sign up for relay and go and brake down. Ask to be relayed there.
When I first had my Bongo V6s were incredibly rare and my local Bongo garage, a Mazda specialist did not want to touch it. I took it instead to a classic car specialist who understood old designs of V6 engines. This might be another possibility.
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
Simon Jones
Post by Simon Jones » Fri Aug 01, 2014 10:47 pm
Have you spoken to Andys Imports about who he would use for mechanical work? You mention you went to see him when you were looking for a Bongo as he was not too far from you.
haydn callow
Post by haydn callow » Fri Aug 01, 2014 11:02 pm
It's a diesel not a V6.....according to the original post.
http://www.coolantalarm.co.uk
Also BMW Clocks
Post by Northern Bongolow » Fri Aug 01, 2014 11:07 pm
they could have got 25 psi readings if they removed the cap and pressurized it through this point. or fit a pressure gauge here and let the bongo go up to this point during testing this is how i do it,
but not that high as the system isnt designed to stand that pressure.
try contacting member -mikexgough- he has a garage buisness and a bongo of his own, he maybe able to help.
New Forest Terrier
Post by New Forest Terrier » Fri Aug 01, 2014 11:37 pm
Apologies all. What confused me was the how many heads question. A V6 has two so I assumed it had to be that for anyone to consider it an issue. The keep clear of steel seal still applies.
mikexgough sounds a good bet for your next move. He is somewhere near you.
hijimhere
Post by hijimhere » Fri Aug 01, 2014 11:55 pm
Wonder where the got the adaptor to pressure test - I have been looking for one`for a year for my sykes pickevant kit.
A block test (test for level of hydrocarbons in the coolant) wouldn't be a bad idea. But I would seriously listen to the advice being given and use an experienced Bongo dealer no matter how far away.
Post by Northern Bongolow » Sat Aug 02, 2014 1:54 am
get a expansion tank flat cap with no spring in it, or cut the seal out, then inflate up the expansion tank overflow pipe with a foot pump that has a pressure gauge in line.
