tycho25
- Apprentice Bongonaut
Post
by tycho25 » Tue Aug 05, 2014 9:15 am
Our indicators are clicking fast when signalling right. We've checked the bulbs, and they are fine. The light on the dash doesn't flash right either, although it makes the faster clicking sound. Left is all working fine.
Any ideas what the problem is?
tycho25
Post
by tycho25 » Tue Aug 05, 2014 9:59 am
Ok - googling, seems to suggest the relay unit. Where might we find this on a 1995 2.5 diesel Bongo?
Post
by g8dhe » Tue Aug 05, 2014 10:28 am
Almost certainly George at BongoSpares will have one
http://www.bongospares.co.uk/
2newbies
Post
by 2newbies » Tue Aug 05, 2014 2:35 pm
Hi, Just had the same problem but the left one,turned out to be water in the indicator lens......good luck Paul
Gasy
Post
by Gasy » Tue Aug 05, 2014 4:03 pm
There are a few relays under the bonnet on the side walls
Think you would want one on the passenger side
Post
by g8dhe » Tue Aug 05, 2014 4:06 pm
Its the unit F1-01 on the diagram below under the dash righthand side I think;
Diplomat
Post
by Diplomat » Tue Aug 05, 2014 6:19 pm
Presumably, failure of the dashboard light will have a similar effect on the circuit as falure of, say, a side repeater bulb and make the circuit speed up.
May not be the relay at all.
Frank
They flew, I took up naturism
Simon Jones
Post
by Simon Jones » Tue Aug 05, 2014 9:25 pm
Frank, I nearly wrote the same reply earlier i.e. instrument panel bulb blown will change the resistance of the circuit and hence the speed of flash. Then re-read it and noted that the bulb was working but also flashing fast (as it would do). My money would be on a dodgy earth or a bulb on its way out. Problem with a relay could easily be identified by swapping right with left and seeing if fault moves or stays on same side.
Jaws
Post
by Jaws » Wed Aug 13, 2014 12:09 am
Simon Jones wrote:Frank, I nearly wrote the same reply earlier i.e. instrument panel bulb blown will change the resistance of the circuit and hence the speed of flash. Then re-read it and noted that the bulb was working but also flashing fast (as it would do). My money would be on a dodgy earth or a bulb on its way out. Problem with a relay could easily be identified by swapping right with left and seeing if fault moves or stays on same side.
Poor earth or other connection will raise the resistance. Are the bulbs flashing as brightly as they should? Classic sign is weak rapid flashing.
Live Bongo and prosper.
TonyW
- Bongonaut
Post
by TonyW » Sat Oct 11, 2014 9:49 am
Hi all ...... have an indicator prob. Passenger side both front & rear not working. Bulbs replaced and fuse checked. There is a fast 'tick' and no light on the dashboard???
Any ideas any of you Bongo geniuses?
Thanks.
helen&tony
Post
by helen&tony » Sat Oct 11, 2014 10:46 am
See "JAWS's" post above...there lies your answer!
TonyW
- Bongonaut
Post
by TonyW » Sat Oct 11, 2014 11:00 am
Thanks Helen ..... yes saw that ..... have the RAC on the way in the hope it can be sorted easily as need to use the bongo
TonyW
- Bongonaut
Post
by TonyW » Sat Oct 11, 2014 1:18 pm
Hurrah! Very nice and down to earth RAC chap done a temporary fix on an iffy relay. Anyone know the best place to get a replacement relay for my 1990 Bongo??
Thanks.
mikeWalsall
Post
by mikeWalsall » Sat Oct 11, 2014 3:02 pm
Ummm ... be interesting what the RAC man did to do a temporary fix ..??
The one flasher unit (relay) works both the left and right flashers .. if one side is OK .. but the other side is not .. to me .. that suggests a duff connection / bulb rather than the relay itself ..
rita
Post
by rita » Sat Oct 11, 2014 3:08 pm
TonyW wrote:Hurrah! Very nice and down to earth RAC chap done a temporary fix on an iffy relay. Anyone know the best place to get a replacement relay for my 1990 Bongo??
Thanks.
A few on Ebay at the moment.
Well done the RAC man for the temp fix ...very unusual for them to do this type of breakdown.
