Hi again,
Wanted to check the best way to look after the lift top as I realise it needs lubrication but not sure which is best thing to use.
I realise there is bound to be an answer on here somewhere but I have looked and can't find anything specific.
Thanks for any tips in advance.
regards
p.s      Timing Belt, any idea what it should cost to get a new one?
						Bongo AFT roof maintenance tips
Re: Bongo AFT roof maintenance tips
It is the same as when you posted 3 days ago
  - see http://www.igmaynard.co.uk/bongo/forum/ ... ge#p638268
Depends on the engine & who is fitting it. For a diesel (belt-only) probably £20 upwards, kits around £40. For V6 with all the oil seals that should be changed at the same time, it's around £500 at Bongo specialist.markley wrote:p.s Timing Belt, any idea what it should cost to get a new one?
