I remember all that and the incredible detail Steve got into. A great bit of work. And as you say - great fun. I think I've lost a little of the experimentor urges I used to have and now am looking for the simplest and most robust device that will do the job and keep my engine safe.helen&tony wrote:Hi
Mike
I have a sensor in the hose coming from the cylinder head....been in there about 6-7 years, and no leaks...and 11 other sensors / gauges...some used when Steve did the cooling system plans...we used the data from here because of the huge temperature differences...it gets a tad hotter, and colder than Japan, so it's a pretty good "go" a what the system was designed for. It's interesting how the temperatures around the system change during the course of a journey. speed related, terrain related, external air temperature, sampling data every 2 minutes, another set done at given distances....also how the head heats and cools in relation to the water passing through...how hitting the right speed maintains a perfect equilibrium....you could tune your MPG by watching the cooling system sensors, as when it's in perfect balance, your doing the perfect speed ...too slow, and the cooling works too hard...too fast and you're burning juice...
It not only helps checking what's going on, but a bit of added fun!
Temp sensor and guage
Re: Temp sensor and guage
- helen&tony
Hi Mike
I'm with you , there, nowadays...except , maybe another experiment next year???...well....two, but I'll wait 'till spring
I will probably look at installing the other 11 sensors -- one day (or year) very interesting data capture though most certainly into that - whats the optimum speed then. I have trouble getting my head round torque peak at just over 2000rpm so spend a lot of time (locally) changing up at that engine speed.
- helen&tony
oh...and I have a whole lot of LED indicators....it's like a flight deck...
Regarding data capture there are pretty good gauges which can be linked to a central serial data capture point and relayed to your mobile 'phone...To equip the Bongo thus would cost more than you could buy a Bongo for....
Seriously, you could get by with a few gauges and you'd be surprised how they improve your driving and fuel economy!
That depends on what the ambient temperature is, the height above sea level, the state of the engine, the make of fuel, the terrain (i.e. the road surface and incline, plus how many times you slow for a village)...Absolutely everything was included in the data we took back then...AND MORE....months of it!...and like as not, Jim, I have gauges you won't need ...EGT , inlet manifold temperature and water/ methanol flow ratehijimhere wrote: whats the optimum speed then.
Thanks Helen - maybe I will - fuel flow sound like a place to start
- helen&tony
Purely personal thought, but first job after coolant would be turbo boost...surprising how gently you can drive if you watch it!...Fuel flow????....are you thinking of tuning the IP ?
- the1andonly
- Tribal Elder
Did you ever do any research on the effect of towing a 1000kg trailer on temperatures attained (rate of change) or even temperature of autobox.
Any help on finding the origional posts would be appreciated (eg timescales or possible titles).
- helen&tony
The plan was to confirm the way the cooling system works...no trailers were used or harmed in the making of the data!
Errr...I still have some of the records, but Steve did the graphs, and correlation of the tests...they'll be on the search facility, and he did the fabulous pictures...It all took a lot of time and constant e-mailing, but it's all there for the viewing!....
