Glow plug light(lack of)
smillingjimmyc
Post by smillingjimmyc » Thu Nov 06, 2014 11:27 am
I've put off asking this in case its something obvious and I look stupid :oops: My glow plug light doesn't work however I can hear the relay click so its ok,the mystery is that when the relay clicks there is an audible beep almost immediatley.Is it possible this has replaced the light,if so why?
98 4wd
Re: Glow plug light(lack of)
Post by Northern Bongolow » Thu Nov 06, 2014 9:08 pm
i would test the voltage at the plug rail just to be sure they are working.
the glow plug light is a dual purpose light, it also acts as a fault warning light for the charge system if it on an early bongo. has yours got a split charge system fitted.
smillingjimmyc
Post by smillingjimmyc » Fri Nov 07, 2014 8:58 am
Northern Bongolow wrote:i would test the voltage at the plug rail just to be sure they are working.
Thanks!Yes its a split system. Had it checked by auto electrician a month or so ago as a fuse went which meant the leisure batt wasn't charging but all ok now.I did mean to ask about the glow plug light/beep but forgot I just wondered if it was the norm for an audible indication as well as a light.
98 4wd
Post by Bob » Fri Nov 07, 2014 9:08 am
I would have thought the beep when you switch on would be a coolant alarm.
You can hear the glow plug relay 'Clunk' but that's all. Normaly.
rita
Post by rita » Fri Nov 07, 2014 9:15 am
This might sound stupid but, have you checked the Bulb.
smillingjimmyc
Post by smillingjimmyc » Fri Nov 07, 2014 11:33 am
rita wrote:This might sound stupid but, have you checked the Bulb.
No,I just assumed the bulb was u/s and i meant to get the auto elec to look at it but I forgot.I had a coolant alarm fitted which displays the temp at exact same time as relay click/beep so no need for light really,the beep was there before I had the alarm fitted though.
98 4wd
Simon Jones
Post by Simon Jones » Fri Nov 07, 2014 1:25 pm
I think Bob was enquiring if you have a low coolant alarm rather than digital temp gauge. The former does make a noise as soon as the ignition is switched on.
Post by Bob » Fri Nov 07, 2014 2:22 pm
Correct Simon, thanks.
Is it possible the glow plug light has to function in order for the plugs to heat?
Post by Northern Bongolow » Fri Nov 07, 2014 8:05 pm
if it has a fault on the charging system, (my previous question) someone may have removed the bulb and installed a non standard buzzer to say the plugs are ok but covers up the annoying flashing glowplug light, possibly thinking it may affect an mot test.
if this turns out to be the case shout again with more details of your split charge system, has it got a zig unit or a voltage sensing relay system.
smillingjimmyc
Post by smillingjimmyc » Sat Nov 08, 2014 9:09 am
Northern Bongolow wrote:if it has a fault on the charging system, (my previous question) someone may have removed the bulb and installed a non standard buzzer to say the plugs are ok but covers up the annoying flashing glowplug light, possibly thinking it may affect an mot test.
It is a wellway full side conversion(2008),zig unit think.I had full service done when I got it(july) I am suprised the lack of light wasn't mentioned then because the garage were very thorough,I'm back there in march for mot so will mention it then.As I say the van starts and runs great so really not an issue for me just wondered why a beep rather than a light.
98 4wd
