Rewording leisure battery devices
Brassbullethead
- Apprentice Bongonaut
Hi guys,
I have just bought my first Bongo and it has a leisure battery fitted.
The problem is, however, that many of the devices that I would like to run off it seem only to be connected to the main battery.
I have never even heard of a leisure battery before now, so please forgive my ignorance.
Do you have to manually switch between batteries, is it done automatically or are the devices hard wired?
Also, if they are hard wired and I need to move some devices across, is it best just to go to a Bongo professional and pay to get it done or is there an easy way to do it?
Any help would be appreciated
Re: Rewording leisure battery devices
Are you sure it's a leisure battery
As some bongos from northern japan have 2 battery's to help starting in the cold
What's is on the main battery that you want to swop over
If you put your location in your profile I'm sure someone local will give it the once over for you.I'd be happy to if you're anywhere near me.
Brassbullethead
Thanks for the replies
The battery has 'leisure battery' written on it.
At the moment, the only thing that I can work out that is powered by the leisure battery is the motor for the tap on the sink.
I would like the blinds, windows and stereo on it
Thanks - I am based in Swansea, by the way and gave updated my profile
Willinton Intelligent Split Charging Wiring Loom
search on here as every one recommends it
- Dr Fingers
Agreed, but sadly no longer made.wonkanoby wrote:Willinton Intelligent Split Charging Wiring Loom
Derek
You will have to check wiring then
Here's is some info about it from Francophile on here
(I been meaning to do this to mine for a while)
Always an answer on here cheers francophile
Blinds in my Bongo work without the key. Mine is a 99 - I wonder if it's a year thing?
No. yours was probably rewired if you have a conversion or Willinton kit.
Below are some simple instructions on how to rewire the fusebox to get things to work off the leisure battery:-
Look at the fuse board by the drivers right knee.
Remove the fixing screws and wiggle it forwards so that the rear is visible.
Counting from top left to right the numbering goes 1 to 8.
Fuses 1 to 5 are fed by a thick white/red from fuse BTN under the bonnet, which is always live.
(the fuse, silly, not the bonnet!)
Fuses 6,7,8 are fed only when the ignition is on via the thick red/black wire.
6&7 are curtains L&R, 8 is cigarlighter & mirrors.
1] If you do not have a secondary battery:
You can either select just the cigarlighter/mirrors or probably easier and handier select those and the curtains so that you can operate them without the ignition on.
Cut the thick red/black wire going in a couple of inches from the rear of the fuseholder for 6,7,8. Insulate the end that comes out of the loom.
Use a short length of similarly sized wire to extend the end going into 6,7,8 and tap it into the thick white/red that feeds fuses 1-5.
If you want to select just fuse 8 for the cigarlighter/mirrors then you would have to identify the blue wire coming out of fuse 8, cut that and insulate the end coming out of the fuse 8. The blue wire going into the loom would then need an in-line 15A fuse fitting and then tapping onto the aforementioned thick white/red that feeds fuses 1-5.
2] If you have a secondary battery you may wish to feed things from that rather than from the engine battery.
The instructions above are modified only by disregarding tapping anything into the aforementioned thick white/red that feeds fuses 1-5.
Instead you would need to connect it/them into an appropriately fused wire connected to the secondary battery.
While you are at it you could also feed all the internal vehicle lighting from that source as well.
To do so, cut the blue/red wire coming out of fuse 1 and insulate the end coming out of the fuse. Fit an appropriate 10A inline fuseholder to the end disappearing into the loom and connect it to the secondary battery.
- haydn callow
Just push/pull the blinds manually when you need to
Brassbullethead
Thanks for all your responses
- camperman160
If you still haven't sorted this problem out, I have Willington kit fitted and work in Llansamlet. You are most welcome to have a look on any work day, just let me know so I can bring Nongo in on the day. Also still have Willington instructions which may help.
Regards
Dave
Regards
Dave
There is an alternative to the Willington kit available - I can't link it as I make/sell it
bongo frenzee
Hi, sorry for resurrecting an old thread but it seems to *almost* answer my question...
Am I right in thinking that to wire the blinds to the leisure battery, you just have to run a wire from the LB to fuses 6&7? Should this mean that the switches in both the front and rear will then operate the blinds without the ignition on?
I've had mine rewired and (up until a a few months ago), the front switches operated the blinds with the ignition off, but the rear ones only worked with the ignition on. I was told that it's a big rewiring job to have the rear switches working off the LB as well - so does anyone know an easy way to do this?
And as mentioned above, a few months ago the front switches stopped working altogether - neither with the ignition on or off. The rear switches still work with the ignition on, and I've checked the fuses which are fine. Any ideas what has caused the front switches to fail?
Thanks.
Thanks.
Living for the weekends...
CUIDADO! VEICULO BONGO!
Yes in principle, what you do is provide two extra fuse socket off of the LB and then run these to the existing fuse panel, move the existing fuses to the new panel, and plug the wires into the lower of the two sockets that hold each fuse on the old panel. That way you don't have to play with the existing wiring and you have now provided the power unswitched directly from the LB so no keys needed in the Ignition. Its actually the normal to provide 4 new fuse sockets and replace 4 fuses in the old panel;
All the above information is great and exactly what I would like to do in my new bongo, Im however confused with which type of connector to use in the fusebox? and which part of the fusebox to connect to, a lot of pictures seem to show the wire coming out of the bottom of the fuse but no connector?
Any help would be great.
Dan
Dan
Dan,
99 V6!
99 V6!
Yes you go into the lower of the fuse connections, which is the fused circuit being supplied, the upper connector goes to the power either direct or via the Ignition switch. The connector can be either a forked with one half of the fork cut off or folded over provided its not too thick, you can get single pin connectors as well if you look around https://cpc.farnell.com/multicomp/dbve1 ... dp/CN02341
