I suppose I may have broken a piston ring but she doesn't sound any different.
Anyone want a lovely tintop with red arrows display smoke.
lazyb5 wrote:hi all, ive tried the italian tune up, and no good, this is a steady burn of oil, when i take off bleed tube its chuffing as i expect, lots of vapour. im heading in the valve stem oil seals direction myself, maybe something i should have done when i had the head off in august.
Dont think its blocked banjo filter as it wouldnt run right would it?
It still drives ok doesnt overheat but smokes.
Thanks for the advice guys.
lazyb5 wrote:Thanks Ady spot on it was a stuck cold start, looks like I will have to replace a couple of vacuum pipes but that's all, running sweet as a nut now
