Emergency!! need to find front anti roll bar links today!!!
hector
Hi does any one know where I can pick up a some anti roll bar links near southampton or hampshire at least?
I need to go and pick them up today or tommorow morning
Veg_Ian
You mean the droplinks? If you can and have alternative transport, take one off and take it along to a decent Motor factor and ask them to do a match. They are a common shape and if the factor stocks "Pearl Products" links or similar he may have a pair in stock.
If you can't then take a look on ebay to get a picture of the droplink. The distance between bolt centres is 250mm and the bolt is M12. See if your factor will work off that. Providing you replace them as a pair you should be able to work with something +/- 10mm of that length.
If you do get one then let us know the part number (it something I'm about to do myself). I think you will find it will be considerably cheaper than those provided by a dealer.
Veg_Ian
Thanks for that Ian, saves me the job of finding the catalogue number. I think I only need the rears but am not desparate so I'll take a rain check if that's ok. I was going to take both front and rear in to my local factor and see if they could make a match for future reference. Thing is I don't see a match for the rears in Pearl's catalogue. I've heard they are the same for the Ford Galaxy but again anything from the dealer is going to prove a tad expensive.
I wonder if you guys can help. I get (sometimes, not always) a slight click/clunk from (I think) front drivers side suspension area when I brake when manouevring and/or change from forward to reverse. Would this be likely to be the drop links (I dont even know what drop links are and how to check them!)? I think I read its best to change them promptly as the bolts become burred and hard to remove otherwise. Is that right?
Good to know if they are cheap and simple to change though. Presume changing doesnt affect tracking etc?
Grateful for any guidance and thanks.
Mike
Mike
- dandywarhol
Veg_Ian
Mike - the droplink connects the anti-roll bar to the car. On the front it comprises a bar with a small ball joint on either end and runs parallel to the suspension leg. When one of the balljoints fail you get a knock usually when cornering and going over a bump. These things should be cheap but there can be a tremendous markup by a dealer for example MR2 front, Toyota price = £71.50 + vat. Pearl Products about £11 inc vat. However, they don't make them for the MR2 but the Vauxhall Senator ones fit nicely. Therefore apply the same logic to a Bongo droplink. Find something that is a near match at your local motor factors or get them off Ian. Yes they are easy to fit and if a bit difficult to come off, a soaking in releasing oil usually does the trick.
Now your particular problem - dunno about the changing from forward to reverse that sounds more like engine mounts. Spend a bit of time working out where the noise is coming from and check the bushes that hold the ARB in place as well as the droplink (jack van up and drop the wheel on to some blocks of wood so as to take the weight off the suspension. Then feel around the wheel and wiggle the droplink. If loose then probably worn, if tight then ok).
Thanks guys and so quick. I'm having a c**p time at work at present (well for about a year now) so great to have BF to take an interest in.
I'll check out things as suggested Ian. The 'problem' I am reporting is very minor in any case as the whole thing actually feels very solid. But best to catch anything (if there is anything!) early I think.
its a 2WD Dandy which will simplify things a little. Thanks again guys, much appreciated.
Mike
Mike
Veg_Ian
Vanmanerik
Clunk Click
Click noise when changing from front to reverse and reverse to front is more than likely to be the brake shoes re-adjusting themselves in their retainers. Nothing to panic about.
